Anybody have Haynes or Chilton repair manual in PDF
Old Apr 21, 2007 | 08:18 AM
QBridge's Avatar
Does anyone here have those manuals in PDF form? I need one to replace the valve cover gasket on my Max. The FSM is useless to me. I found nothing in it about the valve cover.
Old Apr 21, 2007 | 09:06 AM
dfswartz's Avatar
I have the 95-99 Nissan service manual on cd.
Old Apr 21, 2007 | 09:09 AM
QBridge's Avatar
That's the regular FSM Factory Service Manual and I have that also but it's useless. I'm thinking of going into a Pep Boys or Autozone right now and taking pictures of the pages that talk about the valve cover gaskets. I'm so cheap.
Old Apr 21, 2007 | 09:16 AM
andrei3333's Avatar
if a university or tech school has it u can photocopy it there for FREE!! but what are the chances of them having the MAX copy ???
Old Apr 21, 2007 | 03:07 PM
Batxel's Avatar
blah
It's only 10 bucks?!! how can you afford gas?
Old Apr 21, 2007 | 03:09 PM
MaxedOut99SE's Avatar
hahha @ taking pictures of the manuel
Old Apr 21, 2007 | 03:23 PM
nismology's Avatar
The FSM is useless to n00bs, yes.
Old Apr 21, 2007 | 03:28 PM
nismology's Avatar
A quick glance through the FSM produced not only the tightening torque specifications, but the tightening sequence and where to apply the RTV silicone sealant.
Old Apr 21, 2007 | 03:36 PM
QBridge's Avatar
I searched the FSM for valve cover and came up with nothing. Maybe I have the wrong one. I looked through it also at the engine repair part.
Old Apr 21, 2007 | 03:50 PM
sky jumper
nismology is correct. it's all in there. you just need to look a little better.
hint: there is no section dedicated to "rocker cover" removal & installation, but the procedure is covered in a related section.
Old Apr 21, 2007 | 04:45 PM
ThurzNite's Avatar
Goto autozone, ask for this: http://www.autozone.com/in_our_stores/znet.htm
I have Mitchell repair manuals on DVDs.
Jae
Old Apr 22, 2007 | 08:51 PM
jmello's Avatar
I have a pair of manuals for a 95 max. Shoot me an email if you're interested, jmello at gmail dot com
Old Apr 28, 2007 | 07:23 PM
bswersey's Avatar
Got to check that out. Yar.
Originally Posted by ThurzNite
Old Apr 28, 2007 | 07:25 PM
bswersey's Avatar
Which manuals are those?
Old Apr 29, 2007 | 12:12 AM
slinky87's Avatar
of ots the front valve cover itsall 10mm bolts and has a 1 piece rubber gasket that stays in place you do not need RTV start in the center and work your way out loosening the bolts you do ot need to remove anything else but the wiring harness for the coils you can leave those screwed in if you please becareful when tightening , thoug just a slight tourqe down will do fine
Old Apr 29, 2007 | 08:18 AM
nismology's Avatar
Originally Posted by slinky87
you do not need RTV
This is incorrect. If you don't apply RTV sealant at the designated areas there WILL be a leak at the main cam bearing caps eventually.
Old Apr 29, 2007 | 08:32 AM
Nealoc187's Avatar
SLOW
The FSM is useless but you want a chiltons or haynes? wtf...
Old Apr 29, 2007 | 08:36 AM
Kevlo911's Avatar
Kevlo for President
I guess he used ctrl+f to search text even tho the 4th gen pdf's are images
Index > him
Old Apr 29, 2007 | 08:43 AM
nismology's Avatar
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
MichMaxFan
Sep 30, 2015 09:18 AM
