Possible bent frame
Old Apr 21, 2007 | 02:51 PM
MaxedOut99SE's Avatar
Possible bent frame
Really guys is it possible to bent your frame via a bent control arm? I ask this question because about a month ago I hit a deep pot hole, matter of fact a damn sink whole here in nyc. I wasn't going fast nor did I see it, I hit the hole at about 25mph maybe 30. Anyway I heard a loud bang to only pull over and see that my passenger front wheel was bent back. That extremely but enough to where if you make a full right turn the wheel will rub against the wheel well.
In that event I bent my control arm, cool. I replaced the control arm, bushings and sway links on the passenger side.
Now my problem is that I am getting a slight vibration from the front end. Nothing serious and it is only evident bet 25 and 30 mph. Before and after those speeds the car is fine, pulls great no vibration at high speed whatsoever. No vibration when braking.
My mechanic don't know what the hell is causing it, I got the tires balance about 4 times already and rotated still the samething although I've noticed that before the rotation the vibration was alot evident on the passenger side of the vehicle.
Maybe its a slightly bent rim? I'm on stock se wheels.
Well my mechanic says maybe the frame is slightly bent thus causing the vibration. He also said that since I have a brand new control arm on the passenger side and the orginal on the driverside, that the newer control arm is much stronger than the driverside control arm and that most of the stress is being handled on the passenger side instead of distrubting it evenly.
I ask my fellow orgers what do you think?
Old Apr 21, 2007 | 02:56 PM
Xzecution'R's Avatar
it's possible to have a swayed frame if the hit was hard enough but don't think that's the cuase of the problem. did the contol arm come with a new ball joint?
Old Apr 21, 2007 | 02:57 PM
MorpheusZero's Avatar
First thing I'd do is check that your wheel isn't out of true. If you hit a pothole hard enough for it to bend your LCA there's a good chance it did a number on your wheel as well.
Old Apr 21, 2007 | 03:06 PM
Nah it didn't come with one.
Old Apr 21, 2007 | 03:08 PM
Ok cool, I am in the process of buying a set of 17in oem wheels off a org member hopefully this will be cured because I can't thing of any other possible reason why I am getting this vibration between 25 and 30 mph but not at any other speeds.
Old Apr 21, 2007 | 05:41 PM
BEJAY1's Avatar
Conecarver
Agreed, check that wheel. Mount it on a rear hub and spin check it. Maybe keep it on a rear if it is bent. Have a better balancer try and weight it aginst the tire best they can.
Old Apr 21, 2007 | 10:12 PM
You know your right maybe its a bent wheel hub, I'm definitely going to get to the bottom of it.
Old Apr 23, 2007 | 10:22 AM
dave405nyc's Avatar
get the city to pay for your car damage...
Old Apr 23, 2007 | 11:12 PM
Dan_E_Boi84's Avatar
Did you replace your tire??? There is a thing called a Roadforce variance...if a band in the tire is snapped or out of place it would cause a vibration...this could've happend during your accident
If you think it's the tire or rim then rotate tires from front to rear and test drive to see if vibration changes from your steering wheel shaking(shaking steering wheel means one of the front tires are the suspect) to the seat under you shaking(this would signafy that the rear tires are the suspect) ... If nothing changes...then sorry...good luck...
If you have the equipment...
First check tire assymble balance on balance machine...
Check rim offset using a balance machine that offers it....
Check Roadforce Variation using a balance machine that offers it...
Old Apr 23, 2007 | 11:23 PM
PS...I don't think your mechanic knew what he was talking about with the arms being different strengths and the weight distribution...plus...no frame damage will cause a vibration...It'll cause severe tire wear patterns(you'll have cupping or feathered treads on the inner or outer areas of the tread... and possible tire seperation at certian extreme cases...
Old Apr 23, 2007 | 11:41 PM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
not going to happen.
REDinLV
Aug 15, 2024 12:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 8, 2015 11:02 PM
