Clearence issues, any ideas?
Old Apr 27, 2007 | 02:18 PM
pimp349's Avatar
I have a 4th gen. I recently got G35 wheels with their stock tires on my car. Over the past few weeks I noticed that the rear tires have strips coming off. At first I thought it was becasue I was hitting curbs or something. Today I found out its because the side of the tire rubs against the inside of the fenders/wheel well when I turn too sharply or hit deep potholes since the G35 wheels are wider and stick out more. I also have Eibach springs all around and my struts are shot. I have brand new KYB AGX's that I will install in the next week or so. Do you guys think that will fix the problem? Should I put the stock springs back on? If not, any ideas? I'd really hate to have to part with the G35 wheels...
Old Apr 27, 2007 | 03:09 PM
Doriftomodachi's Avatar
What size tires are on the g35? Perhaps try narrower tires?
Old Apr 27, 2007 | 03:23 PM
pimp349's Avatar
Front 225/45/18 Rear 245/45/18
Old Apr 27, 2007 | 05:14 PM
willard00's Avatar
get different tires. its really your only option.
Old Apr 27, 2007 | 06:34 PM
pimp349's Avatar
^^What size? Someone said 245/40/18...will 5mm really make a big diff? I dont have $ to go out and get a set of tires. Should I just switch the fronts and rear for now?
Old Apr 27, 2007 | 06:42 PM
willard00's Avatar
im not sure, got to a tire place and im sure theyde beable to tell you. just tell them what size the tires are now, and then that they are scraping.
Old May 2, 2007 | 06:50 AM
brokedownmax's Avatar
carefull, i hear g35 rims are different sized for front and rear..
Old May 2, 2007 | 06:56 AM
phenryiv1's Avatar
Mod her. Ate her.
Look at the grooves being cut in the tires. Are they more than 5mm deep? If not, then the 5mm will take care of the problem.
If you don't have the $$$ for new tires, you may want to get springs that don't drop as dar, like Tein H-Techs or even H&Rs.
That is cheaper than tires, and you can sell the Eibachs.
Old May 2, 2007 | 07:33 AM
maxima985spd
45 sidewall is too big for 18 inch wheels. I have 245/40-18 with a 40mm offset and i tuck tire in the back which rubbed the tire until i rolled the fenders.
Old May 2, 2007 | 09:47 AM
TurTLe*'s Avatar
i always tought you can run 235/45/17 or 18's generally is the combo i see around here.
Old May 2, 2007 | 06:23 PM
pimp349's Avatar
No they're both 18X8. At least the ones I have, the 7 spoke. The newer ones, the double 5 spoke are 19X8 front and 19X8.5 rear.
Was it a shop that did this or did you do it by yourself?
Well after I installed AGX's and switched the fronts with the rears the problem went away, at least for now. When I get new tires I'll get 235/40 all around, but for now the fronts are a bit wider than the rears, hardly noticable.
Thanks for everyones help.
Old May 2, 2007 | 09:08 PM
maxima985spd
i did it, shops charge too much
pktaske
May 6, 2016 07:49 AM
gustavison
Oct 4, 2015 06:50 PM
pktaske
Sep 4, 2015 08:40 AM
