Where is the MAP sensor?
Hey guys I have a MAP sensor code, that wont go away even after being cleared. So I'm going to make sure its connected right, and then replace it if it just gave up on life. I looked in the FSM but that offered little help to its location. Thanks guys, pics help too!
After I fix this the car is going up for sale
check towards the front next to coolant pipes follow the vacum lines one says boost sensor thats the one a MAP sensor has nothing to do with temp it measures vacum changes in the manifold to measure how much air fuel it should be putting out butnissan puts them there like a fail safe in case the MAF sensor ever fails but its pretty much invisible otherwise to the PCM so just make sure your connections are are tight on it and the vac line is not damaged or cracked
Originally Posted by Don Mazimo
It it's the MAF sensor then it is the box located on the air intake. It has a filament that measures the temperature and helps determine air to fuel mixture... mmmmm ... yeah that sounds right.
WE DO NOT HAVE MAP SENSORS, YOU ONLY WISH YOU DID..
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
