snapped lug stud... what's to be done?
One of the lug nuts on my right rear wheel was cross threaded apparently I went to remove the nut by brute force since the nut was not touching the wheel and therefore not doing anything anyway... and snap!
I have a broken lug stud.
So here is my question. Looking at the FSM, the front lug studs are definitely separate pieces from the wheel hub. I can't tell if the rear lug studs are also separate or part of the whole hub assembly and non-replaceable. Meaning that I'll have to replace the entire hub assembly.
Anyone know?
If I can replace the stud, any good techniques for getting the old one out?
thanks.
Anyone know?
thanks.
I dont see why it wouldnt be like the front, get under your car and take a look.
To replace a broken stud;
1. remove caliper.
2. remove rotor.
3. hammer out broken stud.
4. put new stud in and tap it a little so it will stay in place.
5. put some washers on the new stud, I just use my rotor.
6. use impact gun or breaker bar and start screwing a lug nut onto the stud to pull it into the hub.
7. put everything back on.
1. remove caliper.
2. remove rotor.
1. remove caliper.
2. remove rotor.
1. remove caliper.
2. remove rotor.
^^^Just like that^^^
Originally Posted by ColdSHO
if ur ever planning on using rear spacers, now would be a good time to insatll longer studs, since ull be replacing one anyway.
