Low end torque
Low end torque
I really want low end torque and the only things I can think of would be to do to achieve this is a 2.25" exhaust and a underdrive pulley. Is there anything else I can get to improve this? thanks
The VQ30 has plenty of bottom range torque from the factory, just don't go modifying the intake system or you'll just shift you powerband upwards. Exhaust mods will increase mid and top range power but the underdrive pulley won't do much for your needs. In fact, the underdrive pulley will were out your main bearings quicker. I had one on a different car until, I pulled motor apart.
Also, if you're one of those people that shift at 2000 rpm, start shifting around 3000-3500 rpm, you'll start noticing better acceleration and better fuel economy for not bogging your motor.
Originally Posted by bigwee
Oh ok I was shifting around 2500k and I am only getting about 22 mpg and I couldn't believe it, Ill try shifting higher, but what I'm talking about is the engine doesn't seem to get up and move until about 4500k rpm and I was wondering what I could do to improve the range around 2500k.
Originally Posted by NmexMAX
Jesus. 2500k, what is that? like 2.5 million? I'd say she'd implde @ 8800 or so.
Originally Posted by 99BlackMaxMS
Rwd>>>fwd
FTW!
FTW!
Ya I guess thats it. I used to have a mustang even though it was also it a six it gave you a kick in the pants.
Please dont talk any more... a mustang v6 has power???? chevy astro vans beat on all pre 2006 v6 mustangs...
Originally Posted by f550maranello2
yea the 4.6 liter...
no apparition.. u posted too fast... or me too slow?
Originally Posted by andrei3333
maxima has the same power to weight ratio as a mustang actually
We ARE talking about the 4.6l right?
so you want more low end torque = increasing standard torque reading at earlier rpm
or
you want more response at lower rpm?
I haven't seen changing exhaust will increase your torque at low rpm, but they certainly will at much higher rpm, if done correctly. Otherwise, the easiest way is to change displacement, or strap a supercharger kit on it.
If you want more response, strip your interior, make the car as light as possibke and you get better response.
or
Na I don't want to do anything real big. I'm just looking for mainly bolt ons. I might be wishing for too much.
Ya I had a 94 mustang which had the 140 hp and 215 tq. It was slow as ***** even after I worked on it $2000 later. I did gears, chip, sts, intake, exhaust, and something else but I cant remember right now.
Originally Posted by nismology
Irrelevant. They never came with a 140HP 3.8l V6 like you said.
Originally Posted by materchan
put adjustable cam gears on and back off the cam timing. this might get you more torque, but it will be a dog in upper RPM's
Have fun with that.
http://forums.maxima.org/showpost.ph...7&postcount=16
http://forums.maxima.org/showpost.ph...8&postcount=20
http://forums.maxima.org/showpost.ph...2&postcount=23
