RPM go up when trans is in Gear
Old May 8, 2007 | 11:11 PM
Nismo3112's Avatar
Custom User Title
I have a 95 5spd and just installed the IACV after driving with it off for a couple hundred miles.. (purchased the car with it off) Now when ever I put the shift selector into a gear (any gear) the rpm's raise from ~650 to around 1500 RPM. The RPM goes back down to normal when I put it back in neutral. Has anyone experienced this? What gives?
Old May 8, 2007 | 11:33 PM
ewuzh's Avatar
Running no IACV on a VQ30?
Any other details about the car? Is it running an auto ECU?
Old May 9, 2007 | 09:38 PM
Nismo3112's Avatar
Custom User Title
Well The iacv was hooked up and installed, but the source hose was blocked off because there was no intake installed when i bought the car. (Maf directly connected to TB)
Car is 5spd from the factory running a 5spd ECU.
Old May 9, 2007 | 09:39 PM
Kevlo911's Avatar
Kevlo for President
Reset the base idle.(check stickies)
Old May 9, 2007 | 09:48 PM
Nismo3112's Avatar
Custom User Title
I couldn't find it in the stickies, but are you referring to when you unplug the brown TPS connector, rev it a few times and adjust idle via IACV screw?
Old May 9, 2007 | 09:53 PM
Kevlo911's Avatar
Kevlo for President
Yuppp
Old May 9, 2007 | 10:12 PM
Nismo3112's Avatar
Custom User Title
Yuppp
Benderr done dat.
I did it last since I used the TB screw to raise the idle since I had to drive the car home w/o an intake, and that's when I started noticing it.
Anyone have an idea why the idle goes up after I unplug the reverse lamp indicator connector from the trans? (That's the only sensor that can tell if the trans is in gear)
Old May 10, 2007 | 06:39 AM
Kevlo911's Avatar
Kevlo for President
Bad ground? Maybe that and the IACV share a common wire?
Old May 23, 2007 | 02:10 PM
Nismo3112's Avatar
Custom User Title
Bump, this has happened to no one?
Old Jun 8, 2007 | 11:15 AM
Nismo3112's Avatar
Custom User Title
Bump for any help.
Old Jun 8, 2007 | 11:18 AM
Kevlo911's Avatar
Kevlo for President
TPS calibrated correctly?
Old Jun 8, 2007 | 10:40 PM
Nismo3112's Avatar
Custom User Title
Im pretty sure it is, but I will check. The last owner dropped in a 96 engine with out adjusting/touching anything.
Could it be that I need to use the 1 connector TPS instead of the two connector type found on the 96 engine and up? (car is a 95 5spd from the factory)
Old Jun 9, 2007 | 09:10 AM
Kevlo911's Avatar
Kevlo for President
Yeah I would try that if you can.
Old Jul 15, 2007 | 10:48 PM
Nismo3112's Avatar
Custom User Title
Bump.
Another thing to note is that when I unplug the neutral switch sensor from the engine harness, the rpm's stay at 1500.
Old Jul 16, 2007 | 09:32 AM
Neo Raven456's Avatar
As long as you have your connector plugged into the, I believe, right one (closest to the car center) of the two connectors it will work correctly. a 2 connector TPS is simply for automatics and has something to do with WOT and open/closed loops. I'm running a 2 connector on my 5 spd right now
user 11122324
42
Jul 18, 2022 03:35 PM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
