power steering fluid capacity?
Old May 10, 2007 | 08:48 AM
Spartuss's Avatar
what is the power steering system fluid capacity? I have used a turkey baster 4 times now to suck out the atf out of the reservoir and then refilled with MObil1 ATF synthetic. I wanted to know how many more drains and refills it would take for the whole system to have relatively new fluid?
P.S. I have tried looking on the amsoil site and the owners manual for the power steering fluid capacity but the info is not there.
Old May 10, 2007 | 08:53 AM
matty's Avatar
I had a completely dry system, other than the front cooler, and I used a bit less than a Qt of Mobil One ATF
-matt
Old May 10, 2007 | 09:05 AM
XJinCT's Avatar
<3's the all motor section
heres what ya do....take off the pressure hose at the rack, turn the car on and turn the car lock to lock 5 times...reconnect it and fill it up and bleed out the system...if its that important to you.
Old May 10, 2007 | 09:22 AM
Spartuss's Avatar
thanks for the replies. I'd prefer not to disconect the hose and do a drain and refill a few more times from the reservoir for it to dillute closer to 100% mobil1 synthetic atf.
Old May 10, 2007 | 04:05 PM
andrei3333's Avatar
The manual does not state the exact capacity of that resevoir, but u should do it this way its so easy:
i had a problem with my cooler -- well it was simply not connected
disconnect the hoses
i ate salad out of that container like 30 minutes before i did this (i had to finish the salad quick time i had no other container ;-)
and then reconnect and refill, do this ever 100KM for like 5 times and you should be good for another 3 years
and here is the finished product
Old May 10, 2007 | 07:36 PM
natty99's Avatar
not to hijack the thread, but can someone point out which hose is the PS return line? Nissan told me that mine was leaking (good ole 100 point inspection), just wondering which one it is and if it's easily replaceable.
Old May 11, 2007 | 02:55 PM
Spartuss's Avatar
thanks for the pics Andrei. What type of fluid did you put in there?
Old May 11, 2007 | 03:44 PM
andrei3333's Avatar
the cheapest dexron 3 ATF i could find (wallmart's tech3000 or sometihng like that) thats what the manual calls for, its all the same, no need for synthetic for power steering i can bet $1 000 000 that u will never see and feel any difference.
Old May 11, 2007 | 09:03 PM
Love_00_Max's Avatar
The return line is the smaller hose connected to the PS reservior.
lowpost99
Oct 26, 2025 06:53 PM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
