Problem/question with centerbore
I am having a same problem with some rims off a stock Mazda 626. They had 67 mm centerbore, but the hub cap of the rim was only about 55mm. This is at the outer edge and didn't cause a problem in front, but the rear wheel grease caps stick out about 1/2 inc or more and run into the rim 's hub cap hole. I haven't decided whether to Dremel out the rims or just look for diff ones, but I need to find out if there are press in hub caps that are about 65- 66 mm if I do that. Anyone know where I can find something like that ?
I got the centerbore info from a link here, but it didn't mention the rear grease cap being so protruding. I never thought to check when I bought the rims, since the website showed they were only 1mm larger than Max.
Originally Posted by Fr33way™
Can you use spacers to clear that caps in the rear?
I would put the wheels up for sale while you look for a solution unless you are attatched to them already.
philpoe
Jan 3, 2002 09:05 AM
