New Hood Struts = Amazing
I finally broke down and got some new hood struts the 2*4 just wasn't cutting it anymore and I was sick of the hood falling on my head when the board couldn't be found. Now my hood shoots up and stays. I took an Ebay gamble and bought these and it worked out http://cgi.ebay.com/ebaymotors/95-96...19166899QQrdZ1
$34 shipped I always see posts on here asking where a good place to get them is, I recommend this ebay seller they are more heavy duty then the stock ones.
Originally Posted by maximus_96
the autozone ones only last a little over a year, at least for me...i need to look into this lifetime deal...
Autozone warrants them for life, so everytime they die, you take the dead ones in, and get new ones, free of charge, hence lifetime warranty.Thought it was clear in my 1st post.
Originally Posted by Me
I paid 36$ for AutoZone lifetime pieces. On my 2nd set in 3 years.
some ******* mechanic using vice grips is what caused my hood struts to fail in the first place. The vice grips scratched the metal and that caused the seal to fail and all the oil started leaking out of the strut. Hasn't worked since. I was standing there when the ******** did it too.
Originally Posted by NmexMAX
That's just the thing
rececipts needed or they got your name and info on the "computer"
I dunno. I cut a piece of 1/2" wood dowel that fits in one of the holes under the hood and the other end tucks into a little pocket above the headlight housing. It fits like it was supposed to be there, and it will never ever come loose.
I've considered buying new struts but this piece of wood hides in my trunk and is easier than even changing the struts once.
Dave
Dave
Ok ... this may sound just plain stupid, but how did you get the old set off? I have new ones, have had for a couple months now, and I can NOT get the old ones off. I have tried lots of things, including a hammer (not recomended btw) and I can't pry them loose. The new ones have a snap on clip that fits over the ball after the strut is put on, the old ones seem to have a clip inside somehow.
Originally Posted by nismology
Considering how long the OEM struts last I'm really surprised more people don't spring for them. Might only have to replace them once, ever.
Over engineer something and it will never fail. I tihnk nissan didnt try too hard with these things.
Originally Posted by heynow
the oems don't just "pop" out. You need to "unscrew" the pricly things that go into the strut.
Ok .... then what? lol I have taken the strut off the car, but I for the life of me, can't get that stupid ball out!
$13.33 each ... from Nissan for the strut ball. Crazy! The dealer told me that there is a clip that snaps from the outside, my new ones are like this, but the OEM struts don't have any clip that I can tell. Guess I'll check the bone yard for some.
well ... can anyone point me towards a place to get the ball, 12mm thread, other than the dealer? I have been told that some new struts come with the ball, but mine didn't, and none in town do.
How can something so simple be so difficult?
The problem I am having is that I can't get the ball out of the OEM struts. I have tried and tried, but it will not come out. Seems strange to me, if it goes in, shouldn't it come out? I just can't justify spending $75 to do these. $13.33 + tax X 4 + struts.
Why is the max cursed with this problem of hood struts??? I gotta go get me a set from autozone too...I have a little metal thin stick that fits perfect in there, but I hate having to go grab it out of my trunk everytime I wanna prop my hood....
I just bought and installed the ebay struts. I had to remove the old struts by using an open ended 12 mm wrench to remove the threaded ball mounts from the engine bay and hood. I did not use the old ball mounts with the new struts because the new struts came with new ball mounts and I could not remove the old struts from the mounts. I don't think it would have been possible to "pop" the old struts off of the mounts so I just unscrewed them as I described above.
I screwed the new ball mounts in first (13 mm wrench this time) and then I attached the new struts with a retaining C clip (included with each strut) that tightened the strut onto the ball mount.
So far so good - I will let you know how long they last!
Nissan doesn't make the hood struts. And I disagree with the first statement wholeheartedly.
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
