compressing rear brake pistons
Old May 18, 2007 | 01:01 PM
XtinctWS6's Avatar
im changing the pads on his car and i cant figure out the rear brake pistons. I just saw a thread showing that you have to screw them back in? and not compress them? I have the autozone tool here and i dont know which way to turn them in...clockwise or counter-clockwise. also, do i have to line anything up when im done with that? i read something about lining up the piston and the pad???
Old May 18, 2007 | 01:11 PM
hectorc's Avatar
Upper Midwest Wheel Whore
turn them clock wise, and just make sure the stubs are lined up with the groves on the psiton. Compress them all the way til they are flush with the rest of the inner caliper.
Old May 18, 2007 | 01:44 PM
sports8705's Avatar
exactly..... but unfortunately, if the pistons seem overly difficult to be pressed or impossible to press, they might very well be seized. this happened to me not even a week ago while changing my rear pads. i got the same tool from autozone but when tryin to press the pistons, no matter how hard i tried, they wouldnt budge. the calipers on our cars are a big issue and always seem to get seized, especially the rear ones. just a heads up so u dont get stumped if the pistons dont move. good luck!
Old May 18, 2007 | 02:18 PM
aussie983's Avatar
removing the cap of the master cylinder helps a bit too...
Old May 18, 2007 | 04:41 PM
sinrgsx's Avatar
If you're doing the brakes anyways it's probably a good time to bleed them also open the bleeder screws this would make it easier to screw them in.
Old May 18, 2007 | 05:39 PM
XtinctWS6's Avatar
Thanks everyone. I ended up needing new calipers. I appreciate the help though.
Old May 18, 2007 | 07:29 PM
Eric425's Avatar
Why? There should never be any pressure against the cap of the master cylinder resevoir unless it gets way too full and it starts to backflow..
On another note, now I think there might be a problem with my slave piston. I bled my brakes and the front part of the resevoir above the slave pistons ports didnt pump away the old fluid, which was visibly less clear than the new.
Old May 19, 2007 | 12:46 AM
pmi3096's Avatar
The rear brake caliper on my i30 seized up when i changed the pad. it was a pain. wasnt able to drive for 2days. But they did have over 100k miles on them. Very common problem
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
