Sound of ball joints going bad?
Old May 20, 2007 | 08:17 AM
petemo95se's Avatar
I have the sound out crunching/squeeking coming from my driver-side front wheel area. It is NOT the strut bearing, but it's coming from the wheel/hub assembly. It's not a sharp, metal-on-metal sound, like a brake-wear indicator. It's 2-distinct sounds. They are:
1. When taking off and letting out the clutch, it makes the crunching/squeeking noise until in motion, then it disappears.
2. Once in motion, there's a constant, but VERY slight metal-on-metal sound.
Could it be:
1. Ball joints going bad? They look weathered (142K miles/12 years old)
2. Wheel bearings starting to go bad?
Have others had similar symptoms? Or what are the symptoms you've experienced when your ball-joints are starting to fade? And your wheel bearings?
Old May 20, 2007 | 02:31 PM
nlmaxima's Avatar
Have you replaced front sway bar end links?
Old May 20, 2007 | 03:31 PM
petemo95se's Avatar
yes, they were replaced about 2 years ago. Replaced with Energy Suspension components. Not the RED ones, but black ones that look like STOCK but are much harder.
I don't suspect it's them, but it's worth trying to lubricate. Thx.
Old May 20, 2007 | 03:49 PM
MorpheusZero's Avatar
I doubt it's the endlink bushings, but anything's possible I suppose.
I'd say you're on the right track, if you got a video or something of the sound we might be of more help. I'd put my money on the balljoints, unless your wheel bearings are REALLY worn to shit. I noticed more of a reverberating humming at highway speeds ("vum-vum-vum") when my wheel bearing went.
Jack up your car and try to push around your front wheels. If they have any fore and aft play or up and down play, then that wheel bearing's shot, but if they don't then they're probably okay.
Old May 21, 2007 | 09:20 AM
JtzMax's Avatar
Whatchyou say?
I think you nailed it with CV joints myself. One way to test the CV joint is to turn the wheel all the way one direction - to lock, then take off slow. If it snaps, crackles and pops ... well, I would guess CVs. Like mentioned, a vid would help a lot too.
Old May 21, 2007 | 09:27 AM
maxima985spd
buy a new axle. they are like 170 shipped and you can install it in like 20 minutes.
AaronL
Nov 15, 2020 11:52 AM
Bonka
Sep 14, 2015 11:18 PM
ballerchris510
Sep 11, 2015 05:29 PM
TheMafia
Sep 4, 2015 08:26 AM
