Help ASAP from anybody who can look under their hood
Old May 21, 2007 | 05:30 PM
Eric425's Avatar
Some of the labels I was using came off and now there's two small hoses that I'm not sure connect to what. I've got some pics here. http://www.ls1.com/forums/showthread...522#post778522
The first photo shows the two hoses, which both have one end connected under the throttle body You can also see a place where some hose can connect to the brass tube to right of them, another one up top. Can someone take a peek under their hood and see which one goes where? I also have a big brass tube on the top of the iac... is that supposed to connect to anything?
Old May 21, 2007 | 05:36 PM
bigpulve+'s Avatar
Cant see the photos b/c i am not a member....host them on photobucket and then put them in the tread. I am thinking one is a breather hose...i cant say which one off the top of my head nor without a picture.
Old May 21, 2007 | 05:38 PM
Rit's Avatar
Rit
Ls1
Post the pictures here, and I'll help you out. I couldn't get onto the LS1 site.
Old May 21, 2007 | 05:52 PM
Eric425's Avatar
OK here's the pics on photobucket. Same order as on ls1. 1st 2 pics shows the 2 hoses and brass connectors. 3rd shows the big tube on the iac. Please help quickly.. I'm so sick of this manifold/injector job.
http://i208.photobucket.com/albums/b...p/IMG_0566.jpg
http://i208.photobucket.com/albums/b...p/IMG_0567.jpg
http://i208.photobucket.com/albums/b...p/IMG_0568.jpg
Old May 21, 2007 | 06:14 PM
Eric425's Avatar
Come on guys... itd just take a quick peek under the hood of a functioning max to see where those hoses connect to..
Old May 21, 2007 | 06:44 PM
Eric425's Avatar
Somebody help please! I'm so close to finishing this project! after this just put back the intake box and plug the crap back in.
Someone can surely at least know if that big tube on top of the iac connects to anything, even without need to take the effort to look under your hood? the middle of the screen, 3rd pic...
Old May 21, 2007 | 07:01 PM
joeahuerta's Avatar
Insert witty catch phrase here
the third pic is wicked hard to see. i went outside and took a few pictures, my computer is being slow, ill have them up on photobucket in a few minutes
Old May 21, 2007 | 07:06 PM
Eric425's Avatar
ahh.. thanks so much! You saved my ***. I need to get to work the next day and don't have a car. If I can set you up with any spare parts or anything sometime, let me know! The 3rd pic, it's just the big brass tube smack in the middle of the screen, above and between the brown and pink plugs, directly to the left of the gray plug.
Old May 21, 2007 | 07:18 PM
joeahuerta's Avatar
http://i81.photobucket.com/albums/j2...a/100_4177.jpg
http://i81.photobucket.com/albums/j2...a/100_4180.jpg
http://i81.photobucket.com/albums/j2...a/100_4181.jpg
http://i81.photobucket.com/albums/j2...a/100_4182.jpg
http://i81.photobucket.com/albums/j2...a/100_4183.jpg
http://i81.photobucket.com/albums/j2...a/100_4186.jpg
http://i81.photobucket.com/albums/j2...a/100_4187.jpg
heres the pics i took, i think this is what you were looking for, hope it helps.
Old May 21, 2007 | 08:14 PM
Eric425's Avatar
Thanks so much! I figured out from your pics that the big brass tube on the IAC connects via a hose to the intake... makes sense that the idle air control needs air! :P
The three hoses that go under the throttle look a little different mine from yours, but thanks to that pic I figured out there was another tiny hose that I previously didn't see, and then used the process of elimination to arrive at a setup I think is right for the last one. It should start right up now after I put in the ignition coils.... i hoipe!
Old Jun 18, 2007 | 12:23 PM
Big EEEE's Avatar
Very good pictures
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
