Replacing strut bearings....replace strut mount too?
Old May 24, 2007 | 12:19 AM
99seCALIforniCATer's Avatar
I have been experiencing some seriously sloppy steering wheel play of late and a clunk clunk clunk sound when turning corners. I have come to the understanding that a bad strut bearing can cause both of these problems so I am replacing both of them.
I was wondering if replacing the whole strut mounting piece(rubber insulator, everything above the bearing) would be necessary? I couldn't see how this would effect the handling. Could it?
Old May 24, 2007 | 12:59 AM
matty's Avatar
Being a 99', they are probably still ok, but inspect them when you have em out to the bearings.
-matt
Old May 24, 2007 | 12:29 PM
good idea matt
Old May 24, 2007 | 08:59 PM
ThurzNite's Avatar
I had the same loose steering and clunks. First my wheel bearing died. Replaced that and it helped the problem somewhat... and then I replaced the mounts, which did the trick. While you're in there, replace the strut bearing if it doesn't turn smoothly... it's a cheap part anyways.
Jae
Old May 24, 2007 | 10:11 PM
andrei3333's Avatar
i have the same noises when cornering or when there is a lot of people in the car and going over humps on the road, but the steering feels very precise, not loose
Old May 25, 2007 | 06:28 AM
stephenlc's Avatar
Just get the kyb ones from the group deals section. Order the one that comes with the strut bearing, they are cheaper than going to autozone and its a better brand.
Old May 25, 2007 | 10:29 PM
excellent.....thanks for the advice
Old May 26, 2007 | 02:06 PM
Max Noob's Avatar
i hear the kyb mounts are lower quality than new stock. but should be better than 150k worn ones.
Old May 27, 2007 | 10:19 PM
krbga's Avatar
The KYB Strut mounts are good quality,
I have them on the fronts of my GS400, Camry V6, as well as the Max.
Not a peep, clunk or squeek.
For $60 bucks they will give you piece of mind.
Matt93SE
May 24, 2019 02:58 PM
kingw323
20
Oct 21, 2015 08:36 AM
seesole
Aug 26, 2015 11:22 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
