Reverse light problem
Old May 30, 2007 | 07:34 PM
MadXtreme01's Avatar
just bought a 98 se and when i put the car in reverse the lights blink once and stay off, then i play with the shifter a little (its a 5 spd) and it stays lit. i can deal with playing with it, but i have to take the car to inspection and it wont pass without it working properly. any ideas as to what could be causing this problem. also i first thought it was the bulbs and replaced both of them
Old May 30, 2007 | 07:55 PM
XJinCT's Avatar
<3's the all motor section
might be a pinch in the wires that go to the tranny for the reverse gear...id take off the shift boot...check it out...then get underneath the car and check it out. your're bound to find something.
Old May 30, 2007 | 08:05 PM
Mxrider52's Avatar
I support for what?
If I push down to hard on reverse the lights will go off but like once I left off the shifter or what not they come back on. Dunno if that the type of problem your describing but im pretty sure that normal.
Old May 30, 2007 | 09:03 PM
oldngivout's Avatar
Willing to learn
Reverse/neutral sensor in the bottom of the transaxle.
Get it at your dealer, it is fairly cheap, around $30 or so.
Be prepared to replace the entire contents of your tranny's gear oil when you remove it. Great way to drain it for a refill with fresh fluid.
Old May 30, 2007 | 11:46 PM
id be afraid to replace the fluid now, cars got 160k on it and i dont know if its been done at all, now isnt the time to test it out. I think ill just deal with it for the time being, hoping that ill pass inspection, other than that, i can live with the problem
Old May 31, 2007 | 05:41 AM
XJinCT's Avatar
replacing gear oil in a manual has no bearing on its life. its actually a good idea and only good will come from it.
spidgeon
Aug 18, 2015 05:46 AM
Samedi
Aug 13, 2015 04:05 PM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
yat70458
Aug 3, 2015 01:16 PM
