gear position switch removal
I was trying to change my tranny fluid (manual) and ended up slightly rounding off the bolt that is right by the cross member. Wanting to avoid more issues with this, I decided to move to the gear position switch that is right on the tranny. The FSM seems to talk about removing the one bolt that holds it to the tranny and just pull it out. Well, I tried doing that and ended up cracking the ceramic part of the switch right where the bolt goes it so now it definitely has to come out.
Any one else run into this? Any tips on this besides taking a hammer and cracking the entire thing to bits?!
Originally Posted by DandyMax
Use a needle nose plier, on the two holes in the middle recessed section of the sensor, then pull straight out gently.
are you able to get a small flat screwdriver in there and pry it out? if you can, that may do the trick, if not ... well, maybe a gun would work?!? lol
not that i condone my own actions, but i have in the past actually glued something to a part (like a nut that you can get a good hold of) let it dry, then pulled the part like that. i just did what i needed to for the job to be done. btw ... the nut is still on my g/f's car too ...
if i recall right, i used either JB weld, or epoxy, but i don't recall which, sorry.
g'luck .. hope ya don't need to take it to the shop, not only will they get a good LOL over it, they will charge you for your mistake too ...
if i recall right, i used either JB weld, or epoxy, but i don't recall which, sorry.g'luck .. hope ya don't need to take it to the shop, not only will they get a good LOL over it, they will charge you for your mistake too ...
PM sent, don't worry, I won't charge you much or laugh at you, unless you have a dirty little secret..... like lighted washer nozzles, or chrome wipers, then I'll laugh at you.
Well it's trash now so order another one ($25) and don't take it out until the new one arrives. Then work on rotating it in the bore and finally pull like mad on the wiring.
Dave
Dave
LOL
Dont I know that!!
Yeah, I tried the flat head screw driver thing and its like it come out a little bit and then when you let go, it just snaps back. I'm starting to think that its the stupid o ring stuck to something. That's the only thing that makes sense- I looked at the FSM and both it and the Haynes manual say to just slide it out once you take the bolt off...
too funny man, too funny
i havent succumed to that bug just yet!
Dave
Dave
I actually have a new one sitting right next to me! That's what I was thinking about, maybe twist it a bit and pull out but I dont want break something and have it fall inside, then I'd really be screwed!!
i'm going to try KRRZ350's suggestion tomorrow soon as I get off work to stick a flat head around a few different places and tryand get some leverage. Its never easy
...I'll keep everyone updated....
If it's as brittle as it sounds like it is, doing that will only crack the lipped edge in pieces. I'm surprised the pliers didn't work for you, did you pull straight out without twisting or wiggling the pliers? I've had a brittle sensor issue before also, cracked edges etc but the pliers worked in the middle, as long as you don't twist.
Yeah, I did. Plier in between and tried to pull straight out. Its definitely brittle. Like I mentioned before I highly suspect the o-ring in there. I think if I can somehow get a bit of leverage, get some lubricant in there as suggested and let it soak for a bit, we should be o.k. My first thought once it started breaking off was "I cant believe nissan o.k'd this material for something this sensitive" Its probably the only thing that works well though..
Thanks fellas!!....
side note, I noticed that I have quite a bit of rust on the radiator support- right where the cross member bolts on to it. Off to get some research done on that...
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
