Hey Dan
Old Jul 14, 2001 | 11:17 PM
PeteGT2857's Avatar
Would I really need an Ocillator to check my Snesing part of my Rear Heated Oxygen Sensor? couldn't I just use a voltage meter? It's a pretty simple sensor. and I doubt it works off of frequencies than voltages. What doy ou think?
pete
Old Jul 15, 2001 | 11:38 AM
Daniel B. Martin's Avatar
pete
The sensing element of an Oxygen Sensor cannot be tested with an ordinary meter, but it may be tested with a special-purpose tester or an automotive oscilloscope.
The signal from a healthy sensor varies from a low threshold (around 0.2 volts) to a high threshold (around 0.8 volts), and it sweeps back and forth between those extremes about 10 times per second. If a scope trace shows the Oxygen Sensor signal failing to reach either extreme, or oscillating between them at a frequency slower than 10 cycles per second, that is evidence of a "tired" sensor. If your voltmeter is one of the fancy models (Fluke 87, etc.) you may be able to use it in lieu of a scope to make this evaluation.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
Marc2theMax
Sep 28, 2015 08:13 AM
zmcneely13
Sep 26, 2015 02:26 PM
newtomaxima
Sep 25, 2015 05:16 AM
