scary noise in 96 5sp gearbox!!help
Jun 3, 2007 | 12:35 PM
guys,any educated guesses on this. a loos claaanky sound when going thru my gears! even when im in nuetral , ill be coasting and hear this claanky sond like somethings loose down there?? anyone strongly think they know/ im hoping /just linkage,or bushing.etc. if so do I have a little time,without messing something else up real bad. if its linkage,is it just a little in parts and a big labor bill? the clutch feels fine ,likes its not in the equation
Jun 3, 2007 | 12:46 PM
You'll have to be a little more descriptive. Exactly at what point does the noise occur? Can you make a video of it and post it up?
Jun 3, 2007 | 01:58 PM
I'm guessing chipped gears.
Unless you're lucky and it's something unimportant that's rattling around on something inside the tranny, or it's the throwout bearing, expect this to be expensive. It's usually $400 just to get the tranny in/out in many shops, and that's not counting solving the problem.
Dave
Jun 3, 2007 | 02:21 PM
I had a similiar problem. everytime i rode the gears in the high RPMs i would hear a whearing or loud whining sound. When I down shifted to low gears, pressing in the clutch, I would also hear the noise.
turns out it was the throwout bearing/clutch bearing. Replaced it, and it still makes noise, just not as loud. Looks like i also have a bad bearing INSIDE of the transmission that can only be solved by a transmission rebuild.
YAY!! hopfully the trans will last long enough so I can save up for the rebuild and diff.=)
Jun 3, 2007 | 02:35 PM
its a clanky looseness on the way to each gear,seems equal on each gear,no favorite one,it seems to go in each gear without any more effort/just makes this noise on the way/what does the shift linkage do?what do syrnconizers do? could it be either of those?its right in between a clink and a clunk/its a clank/thanks for trying to help
Jun 3, 2007 | 03:29 PM
i just talked to the guy who i bought the car from. he mentioned that there was a noise when the rods on the tranny moved and was to close to his exhaust shield. my exhaust broke at the main cat a week ago and I know my exhaust is messed up/i,m pretty sure from talking to him that thats going to be it,Ill hope!
