recomended tire psi level for auto-x? (posted here as well just for more input)
Old Jun 5, 2007 | 01:33 PM
G4nismo's Avatar
going to autocross this weekend and need psi recommendations.
tires i have are just sum cheap kumo's. max psi is i think @ 44 psi.
have it set at 35psi front and back right now.
was wondering if thats was ok. should i increase pressure more up front than the back? i will also chalk up the sidewalls to know if i need to increase it or not.
Old Jun 5, 2007 | 01:39 PM
ThurzNite's Avatar
If inches are english, what do metric people use instead of psi for their tires?
I used 35fr 30re recently, but like u already know, it's trial/error.
Jae
Old Jun 5, 2007 | 04:05 PM
pmohr's Avatar
No more Maximas...
Most likely bar. 1 bar == ~14.503 PSIG. That's what they use for rad caps, boost pressures, etc.
EDIT: Not sure if I missed a rhetorical question there, but eh, whatever.
Old Jun 5, 2007 | 05:59 PM
dgeesaman's Avatar
Maintenance Monster
I suggest trying 44psi on all corners, and bleeding down depending on the chalk marks and of course heating and pressure increase.
Dave
Old Jun 5, 2007 | 06:04 PM
LeVeL's Avatar
Just experiment with it.
http://www.tirerack.com/tires/tirete....jsp?techid=58
Old Jun 6, 2007 | 11:58 AM
G4nismo's Avatar
^^^ thank you very much!
thats what i needed. i'm running stock suspension and of course, it understeers a lot and wanted to alleviate that issue.
Old Jun 6, 2007 | 12:13 PM
vnphantom's Avatar
Sorry if I'm off topic a little. I know the recommended pressure for tires by the manufacturer is 29 psi. But I'm running on a set of touring tire (Yoko Avid TRZ) and somehow the front tires look kinda flat a little. Should I pump the pressure up to say 35 psi or no?
And sorry OP for going off topic.
Old Jun 6, 2007 | 12:35 PM
G4nismo's Avatar
it should say on the tires themselves what the max psi is. i usually just go
80-85% of what the max is.
Old Jun 6, 2007 | 02:41 PM
NmexMAX's Avatar
dot dot dot ...
Perhaps you might have better luck here. http://forums.maxima.org/forumdisplay.php?f=50
Old Jun 6, 2007 | 03:05 PM
XJinCT's Avatar
<3's the all motor section
i usually run 40psi in the front and 42 in the rear....i will probably run more in the rear next event because i cant get the rear end to give out for anything...i want a rear sway bar so bad.
Old Jun 6, 2007 | 07:51 PM
G4nismo's Avatar
thanks! just found out one of my tires is not kuhmo and it's max psi is only 35!
kinda pissed about that. cheap tire...
guess i'll prob run 40 front, 34 rear, see how that feels
like your sig Xjin, might have to bust out that MAXIPAD on my max too lol
James92SE
142
Jan 2, 2024 09:23 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Bonka
Sep 14, 2015 11:18 PM
