sunroof HELP!
Old Jun 5, 2007 | 04:34 PM
Mr Willis's Avatar
sunroof HELP!
My sunroof isn't working but i can hear the motor sometimes.It won't tilt up or down or go forward, it will only go back. I have to push it forward with my hand. It rained last night and now my cupholder is full of water
here:http://i46.photobucket.com/albums/f1...2ecc45d61d.jpg
. It was leaking from the area where the sunroof buttons are??????
here:http://i46.photobucket.com/albums/f1...0b8bd6f1a4.jpg
can anyone give me advice just to keep it closed and sealed off. It's sitting just under the roof . I can push it UP into place but when i let go it comes back DOWN.
Old Jun 5, 2007 | 05:29 PM
shissqbob's Avatar
i dont know too much about sunroofs but if you're wondering if it's leaking from where those buttons are, pull down from the front (i believe) part of the plastic closest to the windshield where those buttons are located. it's just held up there by a clip and you can see easier up there
Old Jun 5, 2007 | 07:22 PM
Mr Willis's Avatar
Yeah, there was water in there. Thanks!. I can't believe it didn't short anything out like the overhead light or the sunroof controls. I cleaned out all the water and tried to make the sunroof a little more flush but there is still a gap.
Again people, i can only send the sunroof backward with the control and then i have to PUSH it forward. The tilt feature isn't working although i hear it working????When i press "tilt up" it will make the motor noise and then stop as if it works but the sunroof doesn't move???
Old Jun 5, 2007 | 07:40 PM
BEJAY1's Avatar
Conecarver
Sounds like a broken pivot like mine caused by stuff stuck in the tracks. For me one of the little metal clips off the side of the sunshade came loose and wedged into the track. Helping the motor push the roof open only damaged one of the pivots that lifts & retracts it. I disassembled my roof assembly enough to diagnose the problem and get the glass to sit pretty even with the roof. A screwdriver helps to pry the pivots fore & aft to make it rise & fall.
Old Jun 5, 2007 | 07:48 PM
hiren_patel_83's Avatar
Yup i did the same thing. I took my sunroof apart. But this time I made sure the rubber seals are intact.
Old Jun 5, 2007 | 07:58 PM
shissqbob's Avatar
not sure if you have the factory service manual but sunroof info for me iwas on BT-30 to BT-32....i can't believe it didn't short either.wow. sorry i could'nt help out further. good luck and free bump
Old Jun 5, 2007 | 08:14 PM
Mr Willis's Avatar
Thanks fellas. tomorrow i'll try to just pry it into a flush position and just leave it alone.
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
