windshield wiper arms
Old Jun 6, 2007 | 06:10 PM
chazmcgee's Avatar
which side is witch they have a "A" and a "D"
Old Jun 6, 2007 | 07:27 PM
pmohr's Avatar
No more Maximas...
D is Driver, A is Passenger.
Old Jun 6, 2007 | 08:05 PM
chazmcgee's Avatar
thanks i appreciate it
aznprid972's Avatar
Yep.. I'm spray painting mine right now.
Old Jun 6, 2007 | 09:09 PM
NevadaJack_9's Avatar
Is it possible to remove the arms? I need to paint mine also.
Old Jun 6, 2007 | 10:30 PM
vuiskool's Avatar
I dont see where u can take them off. I need to repaint mines black also, its starting to peel off the reg paint.
Old Jun 6, 2007 | 10:52 PM
chazmcgee's Avatar
at the end of the arm theres a little bubble if you will, you pop it off via butternife or whatever theres a 14mm bolt i believe you take it off and your arms just sittin there pull it off sand it down and get to the task, thanks by the way i was a little confused but i know you can put just one on there in a order and it gets the whole windshield, might not be from a maxima though, anyways thanks
Old Jun 10, 2007 | 09:51 AM
vuiskool's Avatar
um, i dont know if its like this, but my wipers are stuck. I unscrewed the 14mm bolt and they still wont pull out. helpo?
NVM, i found out u just have to rock it up and down. Painting is coming great!
Old Jun 10, 2007 | 09:37 PM
VTonmymind's Avatar
Mmm, fresh lobster
Painting wiper arms. That's on my list of to do's. What grit sandpaper did you use? 2000? Also curious to know what kind of spray paint you're using. Anything in particular or just regular ole flat black from whomever?
Thanx for your insight
Old Jun 10, 2007 | 10:03 PM
vuiskool's Avatar
even though you werent referring to me, i washed mines down, let it dry in the sun, then sprayed Flat black from Rustelon at homedepot. 2 -3 coats of that and a gloss top coat. Looks brand new!
Old Jun 10, 2007 | 11:08 PM
aznprid972's Avatar
I didn't even sand them down since the paint didn't flake off. Just faded. If I had more time, I would of sand them down. It gets the surface smoother and the paint to stick better but I was satisified with my results.
As for paint, I used Semi-Gloss Rustelon(?). Picked up a can at Walmart for under $5.
3 coats later, looks just like new.
Old Jun 12, 2007 | 05:41 AM
VTonmymind's Avatar
Mmm, fresh lobster
Thanks for your input gentlemen.
Reckon I'll go find some Rust-Oleum this weekend and have a go at it myself. Probably get the semi-gloss outright so as skip the final gloss app. Should look the same. Anyway.............
What grit sandpaper did you use aznprid?
Old Jun 12, 2007 | 08:06 AM
vuiskool's Avatar
he didnt sand em
Old Jun 12, 2007 | 08:55 AM
maximabebe's Avatar
I would say start with a 400 then work your way to 800 or 1000.
Old Jun 12, 2007 | 11:34 AM
BlackDOut98LGE's Avatar
Does anyone have the one wiper arm mod done?
Old Jun 12, 2007 | 11:35 AM
Kevlo911's Avatar
Kevlo for President
Please don't
Old Jun 12, 2007 | 12:56 PM
VTonmymind's Avatar
Mmm, fresh lobster
Originally Posted by vuiskool
he didnt sand em
Indeed he didn't. My bad. Reckon I was thinking chaz, but wrote azn. Whoopsie. Anyway......thanks for the inputs again and look forward to rockin my arms soon.
Old Jun 12, 2007 | 01:17 PM
vuiskool's Avatar
mines look beautiful. The best painting i've ever done. I should've taken before and afters. =(
Wash em, dry em, flat black with 2-3 coats, then clear gloss!
Old Jun 12, 2007 | 02:22 PM
anik151's Avatar
does any 1 know were i can find dat little round thing that holds the wipers in place ??? sorry i dont know wat its called
Old Jun 12, 2007 | 03:00 PM
VTonmymind's Avatar
Mmm, fresh lobster
you can still take afters
Old Jun 12, 2007 | 03:36 PM
vuiskool's Avatar
what happended to your old ones? Wore the sockets out?
Old Jun 12, 2007 | 03:43 PM
vuiskool's Avatar
PICS as vtony suggested i could take afters! wont hurt to add pics? =)
they are perfect, i didnt want it too glossy so i chose flat black with clear gloss.
Old Jun 12, 2007 | 03:47 PM
JtzMax's Avatar
Whatchyou say?
Originally Posted by Kevlo911
Please don't
Old Jun 12, 2007 | 03:49 PM
VTonmymind's Avatar
Mmm, fresh lobster
looks great man, good job!
Old Jun 14, 2007 | 08:01 AM
anik151's Avatar
i sure did in a big snow storm i had 2 drive home almost blind
Old Jun 14, 2007 | 07:16 PM
vuiskool's Avatar
lol, that sucks. Hope you find your answer.
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
