!!Constant Squeek!!
Old Jun 8, 2007 | 06:45 AM
96mAx2fast's Avatar
!!Constant Squeek!!
I hear a constant squeek when I am going slow with the windows down. It seems to be coming from the rear passenger side wheel. My brakes are only about 4 months old and they look great. I assume that the squeek is still there at high speeds but I just can't hear it because of the exhaust. Does this sound anything like a bearing or something like that?
Old Jul 13, 2007 | 09:17 AM
96mAx2fast's Avatar
I posted this a while back and no one gave me any feedback. Any ideas what this could be? Bearing? Breaks? I have no clue. The breaks were changed and it still does the same noise.
Old Jul 13, 2007 | 09:29 AM
dgeesaman's Avatar
Maintenance Monster
If it's constant both while braking and while coasting, then do this:
Remove the wheel, remove the rotor, and look for a stone or pebble that got lodged somewhere in there. I had one that got stuck behind my front brake rotor and it drove me nuts until I could find it.
Dave
Old Jul 13, 2007 | 09:42 AM
IIColinII's Avatar
I am having the same problem too, but I was suggested to change the pads.
Old Jul 13, 2007 | 12:40 PM
96mAx2fast's Avatar
I hope it is not a bad bearing or anything. Actually, I think it happens mostly when I've been driving for a few. I guess when it is HOT.
Old Jul 13, 2007 | 12:47 PM
dgeesaman's Avatar
Maintenance Monster
Pads have a metal tab attached designed to squeal when they're worn out.
The OP's brake pads were very new so I assumed he would check those when removing the rotor.
Dave
Old Jul 13, 2007 | 01:08 PM
KRRZ350's Avatar
bearings tend to make a groan/rumble type sound. You failed to mention but is it in any way affected by using the brakes? If it is constant and not affected by using the brakes follow deegeesman post.If it is effected by pushing the pedal I would suspect either A: very cheap pads B: someone throwing pads on and forgetting about it, meaning they didn't properly clean and lube everything, all the caliper/pad attachment points need to be sanded/wire-brushed, sprayed with brake cleaner, then anti-squeal needs to be applied, the guide pins need to also be cleaned and re-greased with special grease. Usually with A you also have B. If it is constant and not affected by using the brakes follow deegeesman post.
Old Jul 13, 2007 | 02:18 PM
IIColinII's Avatar
anyone experienced Rear Brake Groan/Humming Noise After Releasing Brake Pedal problem? I read it needs new parking cable and pad retainer, i was wondering if anyone has different solution to the problem
Old Jul 13, 2007 | 03:02 PM
KRRZ350's Avatar
jack the car up and check it out first, shake & spin the wheel.
Miket2006
Mar 1, 2021 03:55 AM
msellas
Sep 23, 2015 09:16 PM
lrb6805
Sep 17, 2015 04:49 PM
jfl330
Sep 4, 2015 01:44 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
