Replacing Fuel injectors, how do i prep?
Old Jun 9, 2007 | 08:54 PM
CaptainFill's Avatar
Hello,
I am replacing one stock fuel injector and the last time I did it I managed to mess something up because i didnt drain the gas from the line beforehand.
Now that I am doing it again I would like to approach it a little smarter and drain the line first.
So what im really asking is what do i need to prep for a fuel injector change?
Thanks!
Old Jun 9, 2007 | 09:02 PM
mynameispee's Avatar
pull the fuel pump replay and turn the car on until it dies then you should be fine.
Old Jun 10, 2007 | 10:01 AM
95BLKMAX's Avatar
be sure to coat the new injector's o-rings with new engine oil. Makes for a much better seal and this is what it says to do on the FSM if you dont trust me, lol.
When reinstalling the fuel rail, be sure not to crush any of the injector grommets, otherwise, vaccum leak FTL.
Goold luck
Why are you replacing ONE injector anyways??
Old Jun 10, 2007 | 11:53 AM
Thaanks. One of my injectors is clogged and I cant afford 6 new injectors.
Old Jun 10, 2007 | 12:37 PM
Well I replaced my injector and its like a have a brand new car.
It fixed....
Rough shifting
Slow acceleration
Rattling in idle and stopped
Misfiring
Hesitation from accelerating around 1.5k
Heavy downshifting
I cant be happier and it only took 15 minutes.
Old Jun 10, 2007 | 01:04 PM
95BLKMAX's Avatar
tight work man. I bet you're happy. What mods do you have???
Old Jun 10, 2007 | 01:15 PM
No mods, just a stock 95' GLE. Id like to do stuff to it but it has fairly high miles and any mods to it might put more strain on the engine and tranny. Id like to do a 3.5 swap w/ tranny, but i dont have the money for that now.
Old Jun 10, 2007 | 02:13 PM
95BLKMAX's Avatar
DEKs run for ~$400-$600. plus, any mods u do now, like ypipe and intake, can be used on the new motor, 3.5 included :-D. But yea man, take ur time with it and have fun
Old Jan 24, 2009 | 12:29 PM
AlphaDog's Avatar
Just wanted to say thanks to the posters in this thread. I replaced an injector today in my '95 from the info here.
Awesome work guys!
Old Feb 2, 2009 | 06:10 PM
BogardiDough's Avatar
just curious, how much did each injector cost you?
Old Feb 2, 2009 | 06:30 PM
trooplewis's Avatar
And also how did you know you had a bad injector?
Old Feb 2, 2009 | 06:36 PM
pmohr's Avatar
No more Maximas...
You ohm out the injector, if it tests bad you replace it. Typically you do so after failing to find a coil or plug as the fault of a misfire. Injector is the next step
I can get injectors locally for $8 or $100, it depends on where you get them.
Old Feb 2, 2009 | 10:12 PM
aznprid972's Avatar
http://www.vqpower.com/v2/articles.php?article_id=153
kjlouis
Nov 24, 2018 06:09 AM
Cotozic
Jun 28, 2017 08:01 PM
pkfinn
Sep 13, 2015 08:01 AM
Slamrod
Sep 3, 2015 07:38 PM
Balkins
Aug 12, 2015 06:39 AM
