eBay Testpipe install
Old Jun 12, 2007 | 08:43 AM
Majestic's Avatar
Yahhhhhhh
Hey folks I just bought one of those cheap ebay test pipes that are marketed as hiflow cats. It doesn't appear to have an o2 sensor bung. I have a Greddy SP2. will I be able to move the cat sensor to the bung on the SP2? Are the wires long enough? Is the bung the same size?
Old Jun 12, 2007 | 09:06 AM
Iron Scimitar's Avatar
Tha Snatcher
LOL, I just bought one too. I think w/ the 97-99s, there's no sensor for the cat so I dont have to worry about that.
Old Jun 12, 2007 | 09:16 AM
Majestic's Avatar
Yahhhhhhh
Hey Karim. cool. maybe i should have made a local thread.....lol
Old Jun 12, 2007 | 04:08 PM
pmohr's Avatar
No more Maximas...
Yea, IIRC 97-99's have an s-pipe between cat and b-pipe, that's solely there for the 02 sensor (and to make up wasted space by an exhaust redesign).
Old Jun 13, 2007 | 09:44 AM
STILLENGLE's Avatar
i asked a similar question to this and someone said i wouldnt be able to do it cause theres o2 sensors and that would cause my check engine light to go on every now and then and now someone is saying the cat doesnt have a o2 sensor. can someone explain.
Old Jun 13, 2007 | 09:47 AM
NmexMAX's Avatar
dot dot dot ...
95/6 have a rear O2 sensor, the others don't.
Old Jun 13, 2007 | 09:48 AM
Majestic's Avatar
Yahhhhhhh
From what I understand my the 95-96 cat has an o2 sensor in it. The test pipe doesn't have an o2 sensor bung so there is no place for it to go. I have two options. I can get an o2 simulator or find another place for the sensor to go. I'm thinking that I could put the o2 sensor in the bung thats on the Greddy B-pipe. Only problem is that I don't think the o2 sensor wires are long enough to reach. Would it affect anything if I just used regular wires to extend it?
Old Jun 13, 2007 | 09:50 AM
venompwr2's Avatar
the 95/96's have an O2 sensor on the cat, and the 97-99's have one slightly after the cat mounted in the b pipe. Get an O2 bung welded on somewhere or get a sim.
Old Jun 13, 2007 | 09:58 AM
G4nismo's Avatar
just be ready for sum raspynessistity and sum funkadelic odor
had a CM test pipe and uninstalled it cause of that...
Old Jun 13, 2007 | 10:02 AM
STILLENGLE's Avatar
Ok i guess it all makes sense to me now i guess i just have the exhaust shop make me a custom cat. i heard bad things about the Random Technologys Cat i heard they burn up pretty fast. and they melt in stuff.
Old Jun 22, 2007 | 03:08 PM
Majestic's Avatar
Yahhhhhhh
bump.....no answers?
Old Jun 22, 2007 | 03:24 PM
LiGhtSoUt's Avatar
you have 3 choices get an o2 bung welded into the cat, get an o2 sim or just extend the wires. no it wont affect it if you do just make sure to line them up the correct way
Old Jun 23, 2007 | 10:30 AM
Majestic's Avatar
Yahhhhhhh
Got another question. I just got up under the car to start the install and I noticed something.....The CAT's o2 sensor's thread is small. Too small to fit in the bung on the b-pipe. Do you think I could take the direct-fit o2 sensor I have already and just splice the wires.(It's one of the y-pipe o2 sensors.) Are all 3 o2 sensors the same? Do they all do the same job? I don't know.
Old Jun 23, 2007 | 12:46 PM
NmexMAX's Avatar
dot dot dot ...
They are not all the same. The 2 up front control AFR under light load/throttle situations. The rear cat monitors the condition of the catalytic converter. They are also different physically, and also share different harnesses(i.e. plugs/connectors).
The rear one can be simulated using any related o2 simulator.
MaxLife17
Jun 27, 2019 01:37 PM
ef9
Sep 5, 2015 11:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
