Oil consumption
Old Jun 13, 2007 | 11:55 AM
Scruit's Avatar
U wanna try me young boy?
Oil consumption
I have a 96 SE 5Spd and I use a lot of engine braking etc.
Does that explain why I lose 2qt of oil between changes, with no signs of a leak?
It's done since I got the car 7 years ago, and a recent compression and leakdown test showed the engine was 100%.
Old Jun 13, 2007 | 07:18 PM
Streetracer95GX
wow same problem i had except i was in an auto.. now i have 5 speed. I used to down shift like crazy throwing it in to first while i am doing 70... not actually in first but will be asap whenever speed drops... anyway i thought this was kinda cool because i would haul *** with cars until the final moment at the red light n then down shift.... tore up the transmission bad... 5 speed clutch will get bad if you do that too. My problem was there was no leak but i lost 2 and a half quarts and what happened is that the motor shoots to redline and there was a tiny little hole the oil was leaking from and getting burned off instant... i think thats what your problem is too. Now in my 5 speed when i beat on it i can actually smell the oil burning and when i go under it has a good amount of oil but it only leaks when i beat on it (high rpm 7400) This is why i am scared to take it to a shop for them to tell me that the motor is leaking ... that would suck.
Old Jun 13, 2007 | 07:28 PM
TunerMaxima3000's Avatar
that is SOOObad for your car man, I rarely downshift at all, brakes are A LOT cheaper to replace than clutches and trannys, hard on the engine too. I'd guess piston rings but compression checked out? hmmmm.......
Old Jun 13, 2007 | 07:31 PM
Streetracer95GX
says he does engine braking thats the same thing as down shifting.
Old Jun 13, 2007 | 07:43 PM
LOL
no he has a jake on that biotch
Old Jun 13, 2007 | 07:55 PM
Streetracer95GX
lmao.......
Old Jun 14, 2007 | 07:14 AM
pmohr's Avatar
No more Maximas...
You do realize stock fuel cut is at 6550? Unless you're overrevving on a downshift, you won't hit 7400 in a stock Max. Sure, our tachs are off, but not that far off...
Old Jun 14, 2007 | 11:21 AM
Streetracer95GX
I have a reprogrammed ecu
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
