looking for underdrive pulleys...advice
Old Jun 16, 2007 | 12:06 AM
black_maxed95's Avatar
hey im thinking about replacing my underdrive pulley with an aftermarket smaller/lighter one. reading up i see general consensus says its adds about 5-10 hp with the draw back being you get less amps outta the generator.
im just looking to see if anyone has any experience or stories that could be helpful or advice if this is even worth it. also is the drawback of less amps a big deal? i dont have any subs or amps in my car, just an aftermarket head unit
looking around i might be able to get a motosport one for $80. also theres one on ebay (yes i know its ebay so therefore is probly crappy) that i was wondering if its any good: here.
thanks
Old Jun 16, 2007 | 12:15 AM
MaximaSpd85's Avatar
i assume you mean motostorm? i had one, also had two 12s and an amp, and didnt experience any problems with mine.
btw: where are you finding one for $80?
Old Jun 16, 2007 | 12:21 AM
ya sorry, meant motostorm. another orger selling theres.
Old Jun 16, 2007 | 12:31 AM
oh, ok...
well, this is one of those things where you're gonna need to try it out and decide for yourself if you like it, because half of the people are going to swear by it and the others are gonna say you're wasting money. make sure you research the brand because i believe there was one that had oil leak issues and i dont know if it was corrected, so keep a eye on that part. as for my experience, my motostorm didnt hurt a thing and i had a sound system. a/c felt the same, im not sure about the performance aspect though. im going to try it again but this time on a 5 speed to see if theres any difference. so, i too am on the look-out for one.
Old Jun 16, 2007 | 12:39 AM
matty's Avatar
Waste of money
Thats just my .02 cents
-matt
Old Jun 16, 2007 | 02:07 AM
NmexMAX's Avatar
dot dot dot ...
I will w/ matty.
Old Jun 16, 2007 | 01:55 PM
dr-rjp's Avatar
UDP's do not "ADD HP." They may free up a few by reducing the amount of energy expended by the pulley and belt system.
The vast majority of energy produced by our cars is wasted heat energy. With that in mind, anything that you can do to reduce the energy loss to heat will translate into a more efficient engine and drive train.
In other words, a cooler running system will produce more HP than a hotter running one. The UDP will not make your engine run any cooler, however.
Old Jun 16, 2007 | 02:29 PM
1FSTMAX's Avatar
http://forums.maxima.org/showthread.php?t=524401
Old Jun 16, 2007 | 03:23 PM
thanks for the info guys, i think ill just save up for a better mod
Old Jun 17, 2007 | 02:26 AM
maximagasm's Avatar
I noticed a considerable gain on my previous (3rd Gen VE30) maxima in terms of acceleration between 0-30 mph when I installed a UDP. Seems like the folks in the 3rd Gen forum are in general more + on it than on 4th gens. I didn't really notice any difference in terms of AC performance and didn't have any trouble with anything else "belt driven." I was pleased with the results I got for the money I spent and had planned to put one on my 99 SE but maybe not now
Old Jun 18, 2007 | 10:09 AM
Dubbya's Avatar
VK56 Inside
I was wondering how long it would take for someone to post that.
Definitely dont waste your money on one.
Old Jun 18, 2007 | 10:57 AM
alcatranz518's Avatar
Here's the outcome of mine:
Good: Revs quicker bc as said earlier, it 'frees' up hp loss in rotating masses.
Small noticeable improvement in bottom end/ light to light-1-2nd gear pulls.
Bad: At an idle, charging system cannot recover from bass, If in parking lot or at drive in.
A/C produces a bad squeel if under a heavy load (A/C on and blower on high. With lights and Fog lamps on.)
Notes: Since I bought the cheap ebay knockoff, I had to open my crank opening up a litle more (thank god my friend actually owns a lathe). Since it did not fit onto the crank originally. So that was a bit of a hassle.
Was it worth it? I would say for the $40 it was, but not with the added work involved. But I would not pay the price of a name brand one for the improvement I received.
Old Jun 18, 2007 | 02:17 PM
maxiquin's Avatar
in another words, DONT DO IT!
Old Jun 18, 2007 | 03:08 PM
Yes, exactly...it wasn't worth the hassle.
Old Jun 18, 2007 | 03:23 PM
krismax's Avatar
Father of the 00 VI
ive had my underdrive pulley for 8 years no problums.
i say if you want to get every last HP out of your car youll use a underdrive pulley.if you dont care about small gains here and there from certain things than a underdrive pulley isnt for you.
iam gonna be switching to a lighter alternater pulley this year also
Old Jun 18, 2007 | 03:27 PM
nismology's Avatar
Originally Posted by NmexMAX
I will w/ matty.
Co-signed. Stock pulley 4 lyfe y0.
Old Jun 18, 2007 | 08:29 PM
SNOMAX's Avatar
PM me for LCA's!
Are they worth it.. yes.
But there are waaay easier mods to get more HP than a UDP will net you. You could probably pick up a B-pipe and net the same HP as a UDP for the same price, for example. You also won't be hatin' life after 4 hours of trying to get the crank shaft bolt off.
Old Jun 19, 2007 | 06:36 AM
NmexMAX's Avatar
dot dot dot ...
Personal opinion.
Old Jun 19, 2007 | 08:51 PM
24K on da way's Avatar
I have the motostorm pulley "havent had any problem" I love it
Old Jun 19, 2007 | 09:11 PM
well, since these things are so useless, anyone wanna sell me one?
Old Jun 20, 2007 | 06:53 AM
Dubbya's Avatar
VK56 Inside
You can HAVE mine Clicky the link above...........
Old Jun 20, 2007 | 01:59 PM
Ceasars Chariot's Avatar
Old Maxima Legend
unorthodox racing udp !
Old Jun 20, 2007 | 02:19 PM
Maxima_Joe's Avatar
4th Gen Parts King
The only udp i would use on my car would be an unorthodox.
Matt93SE
May 24, 2019 02:58 PM
RayRey21
Dec 5, 2001 01:30 PM
shaftcube
52
Nov 30, 2001 06:06 AM
SC2K1
Oct 5, 2001 04:11 PM
Black VQ
Feb 11, 2001 09:10 PM
