Clock display keeps going on and off.
Old Jul 16, 2001 | 11:31 AM
KEV98MAXSE
This is the factory supplied clock separate from the radio. For some reason, it keeps going out once in a while. Can't figure out why. I checked the fuses and there isn't one for it. Please help!!! Thanks. It's a 98 SE.
Old Jul 16, 2001 | 11:50 AM
cooler2000's Avatar
I have same problem on my 1997 GLE 40k miles maxima, it keeps resetting clock once a while, what it could be? any way to fix this?
Old Jul 16, 2001 | 12:07 PM
Daniel B. Martin's Avatar
The clock is served by three fuses ...
- fuse #18 (7.5 amps)
- fuse #21 (10 amps)
- fuse #40 (7.5 amps)
However, these fuses also serve other loads. If the clock display is the only malfunction, the fuses are probably good.
Remove the clock. This may be done with a small flat-blade screwdriver. Insert the screwdriver blade between the lower right hand corner of the plastic dashboard clock panel and the adjacent softer dash board. Slowly pry the panel up. Continue this at all four corners of the contoured panel until the metal snaps which anchor the panel are loose. Remove the panel by pulling outward and downward.
Note that the clock's electrical connector has four wires. With the ignition ON, backprobe the red/yellow wire. That is the 12 volt illumination supply. If you have 12 volts at the connector but the clock display is lacking, there is a problem inside the clock. 3Gen Maxima owners have this complaint more than 4Gen, and on 3Gen clocks the cause is usually a bad solder joint at resistor R10 or R19.
Old Jul 16, 2001 | 12:15 PM
I don't think you have the same problem. Kev98MaxSE reports a loss of clock illumination. You report a loss of clock battery power. This might be caused by a momentary interruption of power delivered to the clock through fuse #40 (7.5 amps) and the yellow/blue wire to the clock connector. It might be a problem internal to the clock such as a cracked printed circuit board or a bad solder joint. Intermittent problems such as this are difficult to identify and repair.
Old Jul 16, 2001 | 01:06 PM
cooler2000's Avatar
Basically as you are trying to say that it would be cheaper for me to replace my clock unit? How much it would cost me to buy same clock? anyone knows answer?
Old Jul 16, 2001 | 01:56 PM
I'm not trying to say anything of the kind. I provided technical information to help you troubleshoot the clock problem in your car. Use it or ignore it, as you wish.
shilov
Feb 19, 2024 09:40 PM
gavin68
Sep 18, 2021 12:36 PM
Apr 16, 2020 05:15 AM
wiseguy6199
18
Oct 1, 2015 12:28 AM
viperboy
Sep 27, 2015 07:05 PM
