Car "squeaking"
Old Jun 21, 2007 | 06:10 AM
maxihari77SE96's Avatar
Car "squeaking"
Hello to all!
My car has 160k miles on it and I definitely that all the rubber pieces in the suspension are dated by now.
It squeaks a lot when moving from dead stop and stopping. It also squeaks when going over a bump or pothole.
Which parts do you think those are - that squeak?
Is it expensive to change out all those pieces of as many as you can... with polyurethane components? I know energy suspension company - or something like that was selling the "kit" with those for a while, but lost the link on that.
Old Jun 21, 2007 | 06:40 AM
heynow's Avatar
I think that it might be a very challening undertaking for a 3 yr old. But when i had a gooing-over-bumps squak, it turned out to be the swaybar endlink.
Old Jun 21, 2007 | 07:35 AM
TunerMaxima3000's Avatar
check to make sure its not your clutch squeeking<<<<
Old Jun 21, 2007 | 11:54 AM
Surely you're heard of the 15-year old that performs C-sections and such.
In comparison with that, changing out a swaybar endlink seems pale and unchallenging, even for a 3-year old.
Thanks though.
It aint' the clutch, but thanks.
Old Jun 21, 2007 | 08:04 PM
brakes? I ask the obious I know but its easy to over analyze an issue so I have to ask, excpecially because its slow speed turns and bumps.
Old Jun 22, 2007 | 04:02 AM
goldmax's Avatar
The problem might be easier to fix than you think. I have mostly new rubber parts/struts,etc. up front, and have some squeaking like you mentioned. My problem is actually caused by a leaky rear valve cover gasket that drops a small amount of oil down on the steering rack and sway bar. When the oil gets on the swaybar mount, it causes squeaking big time. The problem goes away when I clean everything off. It takes loosening up the mount and taking off the rubber mount to clean it the best...spraying it with degreaser from the outside won't get it. I'm too lazy to replace that gasket, but that is definitely the problem.
Old Jun 22, 2007 | 05:36 AM
heynow's Avatar
That's a possibility too.
Old Jun 22, 2007 | 05:59 AM
thanks guys,
I'm actually very confident that it's the suspension that makes the noise.
It's hard to describe the noise, or the origin of it, you'd have to hear it....
That's why I asked about replacing the rubber components out.
Old Jun 22, 2007 | 06:51 AM
jman7777's Avatar
Originally Posted by maxihari77SE96
thanks guys,
Yeah mine does it too, and you're right, it's hard to pinpoint exactly where it's coming from... seems like the sound is all around. And it only happens when you're going slowly!
Old Jun 23, 2007 | 05:04 PM
Maxi98se's Avatar
I had a squeek from my front end once I replaced the front sway bar endlinks and rubber bushings it went away.....
Old Jun 24, 2007 | 12:27 AM
Crooper_Hedder's Avatar
My rear suspension squeaks a lot, but I determined it's the bushings on my rear sway bar. A friend told me that you're supposed to grease them, although I don't remember seeing that in the installation instructions (this is assuming that I actually read them).
Old Jun 24, 2007 | 09:08 AM
ForeverMAX's Avatar
Hello to all!
i have the same prob its definately suspension, im getting it fixed real soon, so we'll see if teh noise goes away, but we also think it could be the wheel bearing and sway bar?
Old Jun 24, 2007 | 03:04 PM
vofact's Avatar
im no expert but ive heard alot about replacing the 4 bushings in the front/ ithink they are are called the upper and lower control arm bushings/get the energy suspension ones/and the sway bar end links and/or bushings. these things usually go bad between 100 and 160k.your there! these items are almost always the cause of squeaking/assuming that it is not a metal sound/brakes or something else
Old Jun 24, 2007 | 04:26 PM
Aeiou's Avatar
My car does the same thing ( I think). it also squeaks sometimes when you turn the wheel when you are stopped and makes a little humming noise at higher speeds. All three sounds seem to come from drivers side front.
Old Jun 24, 2007 | 05:13 PM
heynow's Avatar
Aeiou, if it makes a humming noise @ higher speeds, then it could be a wheel bearing
Old Jun 24, 2007 | 08:18 PM
maxpeed96plat.'s Avatar
Maxihari squeeks at a stop and turning> check ur strut bearing, may be worn,check ur upper/lower insulators and spring seat for cracks and A-arm bushings. also upper mounts for cracks-all rubber components
Old Jun 25, 2007 | 10:42 AM
Dooley's Avatar
Mine squeaks and creeks - I kinda like it.
Old Jun 25, 2007 | 10:53 AM
3 point slow's Avatar
If its coming from what seems like your back seats or the back window...upper strut mounts. Im pretty sure thats my problem but I just turn the stereo up. lol
Old Jun 25, 2007 | 05:45 PM
maxprivate's Avatar
Black Lion
i had my mechanic at nissan tell me the its the swaybar ends links. also have the same sqeaking when going over bumps. ill post when i ge the links replaced.
Old Jun 25, 2007 | 05:56 PM
dko's Avatar
dko
duck and cover
swaybar endlinks for sure. it took me 2 years to figure it out. while you're at it, change the bushings to energy suspension polyurethane ones
Old Jun 25, 2007 | 06:46 PM
killerVQ30DE's Avatar
Most likely its the bushes for the rear beam.. you've got the beam that goes across the car .. and on each side is like a pivoting support beam that is connected to beam and the car via bushes.. mine are shot and shockplace said thats whats causing squeak.
Old Jun 26, 2007 | 08:05 AM
Are these all expensive fixes? Something I can do on my own?
These endbar links, bushings and such.
Old Jun 26, 2007 | 08:47 AM
Mxrider52's Avatar
I support for what?
If I had to guess id say your swaybar bushings are had it. I know one of mine is cracked right now and when I hit bumps and what not it squeaks. Id just take off the wheel and start inspecting just for a cracked bushing.
Old Jun 26, 2007 | 11:04 PM
You should be able to change the endlinks and swaybar bushings yourself as for the lower control arm bushings, I had mine pressed out and changed with energy suspension bushing. As Mxrider said inspect everything- also if you have oil or PS fluid on your lower bush they're probably shot, the oil breaks down the bushing.
Old Jun 27, 2007 | 12:27 AM
Are these difficult to replace? What about the front bushings? I've considered doing the Energy Suspension thing but from the writeups it sounds pretty involved.
Old Jul 4, 2007 | 08:35 PM
vofact's Avatar
unless your a pretty experienced "car guy' i wouldn't do it /the 4 control arm bushings/not the end links ones/are pretty involved/.plus im sure you need to re align the car/it took firestone/3 1/2 hours/but boy did it feel good after putting the energy suspension bushings!
Old Jul 6, 2007 | 06:28 AM
redwagon29's Avatar
i've been having the same squeaking problem... we narrowed it down to the driver's side front end in the bushings. they can get fairly pricey to replace since there is quite a few of them, and determining which one if not all is squeaking is almost impossible.
i soaked them all with some WD-40 a few times over the course of a week and the sound has yet to come back.. knock on wood.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
