cigarette lighter problem
Old Jun 21, 2007 | 07:36 PM
mge2790's Avatar
my cigarette lighter keeps popping the 15a fuse. it will work for 1 or 2 days, powering the cigarette lighter and ocasionaly a cellphone charger. i dont think what is plugged in is the problem because it doesnt pop as soon as i use it or plug it in. could it just be loose wires shorting it out? suggestions?
Old Jun 21, 2007 | 07:57 PM
95BLKMAX's Avatar
check for short in the wires for it. Probe down the wires with a multimeter checkin for voltage/ continuity. When something changes, bam, look back on the wire for signs of a short. Good luck
Old Jun 23, 2007 | 12:57 AM
Garrick's Avatar
It could just be your Maxima's way of telling you to stop smoking . Do you have anything connected to those wires, using the same power?
Old Jun 23, 2007 | 02:49 AM
eyeball's Avatar
I had the same problem I replaced the whole assembly and the problem went away.
Old Jun 23, 2007 | 11:18 AM
mge2790's Avatar
do you mean you replaced the visible hole (not sure what else to call it) that you plug your various accesories into or do you mean you replaced that and all of the wires that lead to it?
Old Jun 23, 2007 | 12:30 PM
eyeball's Avatar
I replaced the whole assembly that plugs into the wiring harness. It cost about $35.00 at the dealer. This includes a new element and the female section the the element goes into.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
