Different type of starting issue
Old Jun 21, 2007 | 09:33 PM
overbo0st2k4's Avatar
Well since a few others have brought up their starting problems, which granted, are a little more serious than mine, I still figured I'd throw mine in the mix and see if I could get it resolved.
When I put my key in the ignition, and slowly turn from LOCK to ACC to ON/START and try to crank my engine, nothing happens. Well, all the lights that are supposed to come on, turn on, but the engine doesn't crank or make any noise at all.
But if I pull the key out, start over, but instead this time just do it in one swift motion, it starts up fine...
Any idea what would cause this??
Old Jun 21, 2007 | 09:38 PM
andrei3333's Avatar
ignition switch maybe? ususally 99's have this problem, but u got a 98
Old Jun 21, 2007 | 09:42 PM
chazmcgee's Avatar
how much is it to get a new key made for your car and a new switch from the dealershipif you know? i have been curious about it i gota jiggle my **** and its starting to make me feel bad lol
Old Jun 21, 2007 | 11:19 PM
maxpeed96plat.'s Avatar
Sounds like it's your Ign switch as Andrei said > I use a removeable clip just for my car key, the weight of alot of keys can do a number on the cylinders inside the switch.
Old Jun 21, 2007 | 11:41 PM
pmohr's Avatar
No more Maximas...
The tumblers in the mechanical portion of the ignition switch have nothing to do with this problem, it's the contacts on the electrical portion wearing down and getting intermittent or no contact.
The part's about $30 at the dealer, when I checked around a while back it was cheaper and in stock at the dealer, whereas everywhere else it was closer to $45 and had to order.
Old Jun 21, 2007 | 11:48 PM
andrei3333's Avatar
btw i want to ask something related to the OP sorta
is it better to turn the key to ACC and let everything "turn On" and then start the car ? or is it ok to just go ahead and spin the key right away all the way tyll the car starts ?
i heard someone saying that its better to wait just a few seconds on ACC white the fuel system powers on.. any truth to this ?
Old Jun 21, 2007 | 11:51 PM
Thanks that makes sense in his case, when my switch went it was cause of the weight of my keys- similar symptoms though.
Old Jun 22, 2007 | 05:23 AM
heynow's Avatar
ignition switch, i have a 97 and i had that replaced @ 120K
Old Jun 22, 2007 | 06:18 AM
So what exactly is the part I need to replace? Also, is it something that is easy to replace?
Old Jun 22, 2007 | 12:38 PM
hiren_patel_83's Avatar
it's your ignition swtich. SAme thing happened to mine. Replaced the ignition switch and now it works perfect.
Old Jun 22, 2007 | 12:43 PM
maximafrenzy's Avatar
Fuhget About It.....
Search for DaveB
His number is 8882546060 Its like $23+ shipping tell him your calling from teh .org, to install it is easy I posted on a thread a couple of days ago just search back a day or two to find it.
02PearlSE
Oct 7, 2015 02:12 AM
official_style
Aug 29, 2015 10:10 AM
homewrecker
Aug 24, 2015 08:56 PM
Stagnet04
Aug 16, 2015 11:15 PM
