Strut Mount question
Old Jun 23, 2007 | 07:25 PM
heynow's Avatar
Hello, my car pulls to the right past 30mi/hr and i can feel every little bump through the steering wheel. I went to get an allignment today, and the guys said that the cause of all that are worn strut mounts (i've had new tokico blues installed, but the strut mounts were re-used). SO, I have new struts, swaybar bushings/endlinks, and new LCAs/bushings, i had them check all of those as well as tie-rods. My left tire shows wear along the outer edge, the right is not as bad, but still shows some wear(new Bridgestone potenzas, btw). So looking around, i see the strut mounts with bearings included, but would that be enough to solve the problem?
http://www.trademotion.com/partlocat...=8&catalogid=1
Old Jun 23, 2007 | 07:46 PM
Fr33way™'s Avatar
Wild for Width
How were your alignment numbers?
Old Jun 24, 2007 | 05:10 PM
heynow's Avatar
Front: Left Front: Right
Camber: 0.0 Camber: -0.1
Caster: 2.3 Caster: 2.6
Toe: 0.10 (B4 -0.13) Toe: 0.09 (B4 -0.24)
SAI: 14.5 SAI: 14.6
Old Jun 25, 2007 | 06:20 AM
heynow's Avatar
so.....any reccomendations ?
Old Jun 25, 2007 | 06:40 AM
Kevlo911's Avatar
Kevlo for President
Strut mounts usually make noises when they go bad. Do you hear little noises when you go over bumps?
Old Jun 25, 2007 | 07:12 AM
heynow's Avatar
i hear like a little "swish" kinda noise when i go over bumps Otherwise my suspesion is silent.
Old Jun 25, 2007 | 09:24 AM
heynow's Avatar
http://www.putfile.com/pic.php?img=5790775
Old Jun 25, 2007 | 09:29 AM
Kevlo911's Avatar
Kevlo for President
DO NOT buy KYB strut mounts. Only get OEM. KYB ones die quickly.
http://www.onlyfactoryparts.com/index-main.htm
Buy everything from there or call DAVEB
Old Jun 25, 2007 | 10:01 AM
max ride 41's Avatar
i got mine at the dealer for 37.50 a peice and autozone one's were the same price, so i would call your local dealer and see if you can pick them up for that price.
Old Jun 25, 2007 | 10:50 AM
heynow's Avatar
gotcha, thanks for the heads-up
Old Jun 25, 2007 | 11:12 AM
heynow's Avatar
i can't seem to find any other place that has the boots that go on top of the strut...and that rubber piece that goes in between the spring and the strut (sorry, don't know the right names)
Old Jun 25, 2007 | 11:18 AM
knight71's Avatar
Strut bellows or strut boot.
Old Jun 25, 2007 | 11:27 AM
heynow's Avatar
I thougt as much, thanks what about the rubber piece that goes in under the spring and the strut (insulator, i guess?)
Old Jun 25, 2007 | 11:44 AM
Kevlo911's Avatar
Kevlo for President
Look in the stickies for suspension threads and part numbers, I am closing this for now. PM me if it doesnt fix the problem and you need it reopened.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
