vafcii broken?
Old Jun 23, 2007 | 07:43 PM
killerVQ30DE's Avatar
vafcii broken?
About to install a 2nd hand vafcII and powered it up just to have a look.. well the wheel turns a red/yellow color and theres no display.. is that normal?
I'm hoping it just needs sensor input .. but thought display would come on anyway.
Old Jun 23, 2007 | 09:18 PM
maxgtr2000's Avatar
KH3 by popular demand
I have an old vafc 1 I just tested it out. If only one ground is hooked up the orange lights will come on only. If both grounds hooked up the unit comes on. In the installation instructions both ground must be hooked up. One is black the other is brown.
Old Jun 23, 2007 | 11:42 PM
Thanks your a life saver was having a panic attack.. need to slow down and read the manual I think thanks again Will plug it in again and retest
Old Jun 24, 2007 | 10:05 AM
4x4Max's Avatar
Yeah you're fine. Mine did that as well.
Old Jun 24, 2007 | 01:37 PM
Nothing worse than hacking the ecu wiring to find out it didn't go, thanks.
Old Jun 24, 2007 | 11:08 PM
paemt6220's Avatar
HAd same problem with my SAFCII. Wires up almost the same way. There are VERY SPECIFIC directions on wiring the ground wires.
Old Jun 25, 2007 | 01:25 PM
Originally Posted by Kevlo911
I'm sure you'll know
I'm going to wire up a vafcII and I would like to use the o2 wire I have a Cefiro(vq30) so don't know pinout for o2 wire, do you think I could just tap the o2 wire directly after the sensor rather than ecu pinout?
Old Jun 25, 2007 | 01:27 PM
Kevlo911's Avatar
Kevlo for President
Don't use that wire. Get a wideband sensor because the stock sensor won't give you the readings you want to tune.
Does it matter which order the postive wires go in? in the vafc ecu diagram it shows 2 postive wires but doesn't say which goes closest to ECU the RED one or Red wire with Black stripe? Doesn't it matter like it does with the ground wires (black & brown?)
Old Jun 25, 2007 | 01:28 PM
Kevlo911's Avatar
Kevlo for President
Doesn't matter.
Old Jun 25, 2007 | 02:44 PM
Doesn't matter.
thanks
I know its not accurate but would like O2 feature to show 'something' I have looked briefly at WB02 but the systems are all very expensive, I think I would break even with a dynotune cost ($NZ350/$US268) for the amount of tuning I would need.
So I want to hook it up and not tune with it, can I splice the o2 sensor or no you think?
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
