5speed swap FINALLY done.. wheres the TCM?
Old Jun 24, 2007 | 11:06 AM
tikiboom's Avatar
I need an intervention
Soooooo after spending a long time doing this swap and several speed bumps its come to the point where im driving it 5speed style. woohoooo
But litterally all my instrument panel lihgts are on (ABS, TCS OFF, SLIP, airbag and SES) I figure the ecu is looking for an auto tranny and not finding one and i havent reset the computer yet either. So i want to unplug the TCM, which i read in someones thread, is underneath the BCM and plugs into a wide blue connector. I dont have anything under the bcm and ther.e is no blue connector that i can see.
Does anyone have any clues as to where the TCM would be on a 1999 (canadian) maxima SE?
Old Jun 24, 2007 | 11:24 AM
Tatanko's Avatar
Bacon Lover
It is indeed under the BCM. It will be easier to get to and unplug if you remove the BCM (don't need to unplug it, just get it out of the way). Just remove the three 10mm nuts holding the two boxes in the holding bracket and slide them out of the bracket. Then you can unplug the TCU and remove it from the car for some weight savings
Old Jun 24, 2007 | 11:44 AM
GriffinW's Avatar
I just finished my swap yesterday and i love the 5-speed. We unplugged the whole tranny computer that is behind the ash tray and im not getting any lights on my dash, but I do have two codes. But those aren't very important.
Old Jun 24, 2007 | 03:46 PM
pmohr's Avatar
No more Maximas...
TCM or no, the airbag light shouldn't be on. Not too sure about the ABS light either, unless that ties in with the TCS system and is lit when 'TCS OFF' and 'SLIP' are.
Like Tatanko said, it should be underneath the BCM behind the radio. Can you take a picture of where it should be? Weird that it's not there.
Anyone know just how deeply the TCS system ties into the TCM? I'm not sure how TCS works on the A32 (since it was only available one year), if it's braking, timing retard, upshifting, etc.
Old Jun 24, 2007 | 04:23 PM
NmexMAX's Avatar
dot dot dot ...
TCS = ABS sensor related, (i.e. difference in wheel speed re: all 4 different wheels)
Old Jun 24, 2007 | 04:41 PM
pmohr's Avatar
No more Maximas...
How does it enforce traction control though? Brake application, engine power output control, or something else?
Old Jun 24, 2007 | 06:31 PM
NmexMAX's Avatar
dot dot dot ...
I'm guessing fuel.
Originally Posted by 2000.0 FSM
TCS (Traction Control System) Operation
This system is designed to limit wheel slip during acceleration by cutting fuel to selected cylinders and changing transmission shift schedule. The ABS/TCS control unit monitors wheel speed slips through the ABS wheel sensors and determines the desired torque reduction needed to minimize wheel spin.
I'm guessing it's the same for A32's. A33B's also get DBW feedback as well as fuel.
Old Jun 25, 2007 | 06:39 PM
The Jackal's Avatar
I heard the 5 speeds in the 4th gens went out easily. Is there any truth to that?
Old Jun 30, 2007 | 03:36 PM
tikiboom's Avatar
So yea, the tcm was under the bcm. I could see it the whole time but i was going by the fact that pictures ive seen on here showed 1 long, blue plug. Mine had 2 smaller, white plugs plugged into it. But i did a search on the part number written on the metalic box and it turns out it is the TCM.
My ABS,TCS OFF, and SLIP lights are still on. I'm starting to think that either its because i have the automatic speed sensor in my 5speed tranny (mine didnt come with one, long story) or because i damaged an ABS sensor during the swap.
Airbag light went off after i reset the ECU.
Old Jun 30, 2007 | 03:38 PM
tikiboom's Avatar
oh and that clutchnet 6puck sprung hub/red 2x pp combo w/ a B&M short shifter grab like a b1tch
I think i stalled the car 10 times before i got used to it
Old Jul 1, 2007 | 10:12 AM
NmexMAX's Avatar
dot dot dot ...
That's why all those lights are on.
Old Jul 9, 2007 | 04:18 AM
tikiboom's Avatar
Turns out i forgot to plug in one of the ABS sensors in. I had so many plugs left over after the swap (from th auto tranny) i guess the ABS one just blended in and i forgot it about it lol.
The TCS,SLIP and ABS lights are all off now. Which is kind of reassuring since i was afraid i would lose traction control but i guess its a function of the brake system and not transmission
TallTom
57
Oct 14, 2025 05:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
