Help tring to program key fob but can't get light to flash after inserting key
Old Jun 24, 2007 | 12:02 PM
euromaxima's Avatar
for some unknow reason I can't get the lights to flash when i insert the key in six times. I have tried many times it even did it like 10 times and still no lights flash. Has anyone had this problem? Its my blue maxima not the white one. Anyone have any ideas?
thanks
Brandon
Old Jun 24, 2007 | 12:23 PM
vuiskool's Avatar
sweet rides. Did you get in the car, lock it, and insert it 6 times under like 7 seconds?
Old Jun 24, 2007 | 02:48 PM
euromaxima's Avatar
yes I tried all that. it wont work for some odd reason
Old Jun 24, 2007 | 02:55 PM
vuiskool's Avatar
is it equipped with Security and Comfort?
if it is and it still dont work, PM me if ur interested in selling the key fob if u dont need it.
Old Jun 25, 2007 | 04:33 AM
euromaxima's Avatar
Anyone else know or have any ideas?
Old Jun 25, 2007 | 11:15 AM
AlpineGt66's Avatar
do the doors have to be closed?
Old Jun 25, 2007 | 12:56 PM
Cdg2125's Avatar
did you have a key fob before? Usually if it doesn't blink it means you do not have security in that car. If you do have it then something could be wrong with the unit.
Old Jun 25, 2007 | 01:06 PM
vuiskool's Avatar
yes the doors have to be closed.
Old Jun 25, 2007 | 03:17 PM
bhunter's Avatar
Sometimes you can do it too fast. Fully insert the key and fully retract it each time.
Old Jun 25, 2007 | 05:15 PM
99BlackMaxMS's Avatar
That happened to me. Just make sure that you place it in and out COMPLETELY 6 times within those 10 seconds and the hazards should flash....
Old Jun 25, 2007 | 08:16 PM
Snypa's Avatar
DAMNN, im having the same problem and its pissing me off,cause then im afraid of buying the key fob off ebay and then it wont make any sense afterall.Let me know what the deal is euromaxima, cause im doing the exact same thing and my car is equipped with the system.
Old Jun 25, 2007 | 09:03 PM
vuiskool's Avatar
just sell it to me if they dont work. =)
Old Jun 25, 2007 | 09:09 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=387892
http://forums.maxima.org/showthread.php?t=353418
http://forums.maxima.org/showthread.php?t=317689
Old Jun 26, 2007 | 05:10 AM
euromaxima's Avatar
I guess something is messed up nothing is working and im doing the direction right so I will probably have to buy an aftermarket keyless entry kit.
Old Jun 26, 2007 | 05:36 AM
nexgenmax's Avatar
R34
The instruction should program your remote. First time I tried it, the light didn't flash. So I tried again fully insert the key and try to do it the correct way, and it worked. Hope you don't have to spend money just b/c of this.
Old Jun 26, 2007 | 03:59 PM
Snypa's Avatar
Its still not working for me guys.I do think im doing correctly too, it cant be that hard afterall.First thing up, how do i know that my system is still working.?I beleive its working,because when i close all doors with the key it then starts to blink,but i wanna make sure i know how to do it before buying the key fob.Help Guys.!!
Old Jun 27, 2007 | 08:59 AM
maximafrenzy's Avatar
Fuhget About It.....
You need to troubleshoot guys, check your antenna wiring. 1st check wires on the exterior antenna, if they are cut do a clean cut and seal. 2nd is to check the internal antenna that would be the wire leads on top your defroster, maker sure there are no breaks in those line. Then the obvious question would be is did you replace tha battery in the fob? And if you did, did you clear the codes out of the fob? I think you have to place batt upside down. If you do a search you will find many troubleshooting techniques to help you. I think these guys have some....http://www.nissanhelp.com/
Old Jun 27, 2007 | 09:38 AM
NmexMAX's Avatar
dot dot dot ...
Where is the fob antenna?
I never knew about that I knew it was in other vehicles w/o a physical metal antenna for the radio.
Old Jun 27, 2007 | 11:26 AM
The antenna is connected to the fob ecu the wiring on mine was cut, I did a clean cut on it and it worked.
If you pay attention to your defroster area, the first section of wires on top that do not run in uniform with the defroster wires....that is your internal antenna. Check it out, I know this cause when I got my max, the key fob didnt work and I think in the service manual it lists it as a poss. cause of failure when troubleshooting it....Too lazy to make an image but I just looked it up page EL-120 will show it to you.
Old Jun 27, 2007 | 12:39 PM
NmexMAX's Avatar
dot dot dot ...
Thanks for the reference, just found it.
Old Jun 27, 2007 | 03:19 PM
Its cool ....to the OP check out the service manual at EL-page 256 and down to help you better.
Old Jun 27, 2007 | 05:56 PM
Snypa's Avatar
Ok,guess i will go ahead and lookup that page and see what can happen from there.Thanx alot people.
mvm062
Nov 30, 2020 09:00 AM
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
