Putting Headlights back togethar
Old Jun 24, 2007 | 07:16 PM
Powerman5115's Avatar
Hey. I'm finishing up one of my headlights retro fit with projectors. There is not enough glue on the headlight to make a good clean seal. Should I bake the headlight to heat the glue up. Then take it out and put silicone sealant around the seal and put the 2 parts together? Or put the silicone on before I bake it. How has everyone else done it?
-Mooney
P.S. Do you lay the housing on its side or face up? It seems like if it were on it's side the glue would run on the inside.
Old Jun 25, 2007 | 06:49 AM
nexgenmax's Avatar
R34
From what I have read, they put the headlights together then put the sealant. I don't think high heat is good for sealant.
Old Jun 25, 2007 | 07:41 AM
maxgtr2000's Avatar
KH3 by popular demand
I don't understand you saying there is not enough. When you take your lights apart try not to scrape off any of the sealant unless absolutely necessary. Even if you take some off there should be enough to seal it back up. A little silicone on the lights should be fine, the lens would have to be kinda far away from the reflector rim for it to leak. Happy retrofitting.
Old Jun 25, 2007 | 01:00 PM
Cdg2125's Avatar
you most have done something if you don't have enough glue. The light needs to be reheated to put things back together or the glue is just hard...you did do that correct? If so then the light should go right back together unless you pealed out the glue when you took them apart....
Old Jun 25, 2007 | 02:05 PM
I didn't do anything to the glue. There was already some space between it (meaning I can blow air through). I put silicone on the housing, put the two together and stuck it in the oven. It worked well. I'm just afraid there will be condensation if it's not completely sealed.
Old Jun 25, 2007 | 02:10 PM
ewuzh's Avatar
Get some Nissan Rubber Butyl sealant. It is black in color and doesn't flake, discolor or ever dry out. Best thing ever and it is free from the dealer. I used silicon the first time I retro'd and I kind of regretted that decision.
And as far as putting them back together, you need to first heat the original glue again, put the two halves together and then add more sealant around the cracks to prevent condensation.
Old Jun 25, 2007 | 04:51 PM
JetBlackMax83's Avatar
That "glue" is called butyl sealer and nissan sells it if you wanna buy it here is the link http://performancenissanparts.com/pr...id=5577&rsku=0
JRod28
Dec 29, 2023 09:56 PM
kingw323
20
Oct 21, 2015 08:36 AM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
