steering problem
Old Jun 27, 2007 | 03:50 PM
nishfish871's Avatar
steering problem
At low acc the steering wheel is turned to the right but as soon as i smash the throttle a bit the steering wheel shifts to the middle and returns after you let off the acc. When i brake, the steering wheel moves back to the middle again. this is really gettin annoying i hope it is only something minor like alignment.
Old Jun 27, 2007 | 05:31 PM
swimster144's Avatar
My first inclination would be to say alignment. It could also be that one wheels camber is off by a bit, and the others is off as well, but not by as much. This COULD result in a weird direction when car is just inching along, but when you mash the throttle, you get torque steer and maybe it is lining it up somewhat when throttle is mashed. Also, make sure nothing is loose where the wheel meets the axle as well as where the suspension bolts to the axle.
Old Jun 27, 2007 | 07:42 PM
heynow's Avatar
I've heard theories that bad LCAs/bushings can cause the car to pull in a certain direction under acceleration. If you take it in for an allignment, the guys can check those out for you before they do anything.
Old Jun 28, 2007 | 05:04 AM
so alignment will be a start to fixing the problem. then if there are other problems, replace the bushings.
Old Jun 28, 2007 | 05:55 AM
heynow's Avatar
Yeah,the techs are supposed to check the suspension/steering components prior to doing the allignment. SO just take it in, and make sure they give it a look-over.
Old Jun 28, 2007 | 08:39 AM
ya but those doe does will do alignment then tell you, you have problems after so they make that $$$. maybe ill find my friend to look at it.
Old Jun 28, 2007 | 08:47 AM
heynow's Avatar
well, they have to check the stuff before they even touch it. If something's wrong then they'll just tell you that they can't do a proper aliignment until you fix it.
Old Jun 29, 2007 | 04:59 AM
could a clunk for example when i go over speed bumps only on the passenger side make a difference? Sounds like my shocks are shot also. Ive replaced my cv axles a load of times and it doesnt have the same sound effect as cv's.
Old Jun 29, 2007 | 05:09 AM
heynow's Avatar
A clunk could be worn LCA bushings (which is most likely your problem) or swaybar bushings.
Old Jun 29, 2007 | 08:23 AM
what does LCA stand for?
Old Jun 29, 2007 | 09:03 AM
DJ420's Avatar
Bad Mother Fornicator
LCA = lower control arm
DJ (=me) (:
Old Jun 29, 2007 | 10:31 AM
heynow's Avatar
DJ (=me) (:
hah...ZING!!
Old Jun 29, 2007 | 11:03 AM
derr im stupid
Old Jun 29, 2007 | 11:09 AM
sagamax's Avatar
Give me a Bud Light Holmes
my car does something similar on my car its the steering rack bushings
Old Jun 29, 2007 | 05:16 PM
but mines is to the extreme now. i might take a video of it so show how crazy it is now. crap i went to advance auto today and asked for lca bushings but they dont sell it...i wonder if they sell steering rack bushings.
Old Jun 30, 2007 | 08:40 AM
are there any aftermarket brand bushings available?
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
slowlifer
Sep 8, 2015 05:53 AM
