Groan when AC starts
Old Jun 28, 2007 | 08:38 PM
Crooper_Hedder's Avatar
I noticed when I was sitting at a stoplight today that when I turned on the AC it groaned a bit, and then made a quieter groan when I turned it off. I did this repeatedly. AC works just fine, though. Should I be concerned?
Old Jun 28, 2007 | 09:19 PM
SVI30's Avatar
If there are no visible oily spots near hose connections etc, there is little you can do about it. If you can see oily spots, you may want to add some oil. The total amount in the system is about 7-8 oz of PAG46 oil. There are freon canisters (R134a) that has 0.2 oz of PAG46 oil loaded in them.
My compressor failed around 70K miles which is short. And the compressor including the new one do groan when they are started in my car. The Calsonic CWV618 compressor used in 4G cars is designed to run all the time. See the other A/C post.
Old Jun 28, 2007 | 10:09 PM
maxpeed96plat.'s Avatar
Try adjusting your belt, I think this is common when your car is on then turn on A/C because of rpm's drop/increase on initial start up of a/c. If it's leaking oil it's probably leaking refrigerant also so check your pressures fix what's damaged and add PAG if need be.
Old Jun 28, 2007 | 11:56 PM
go to jiffy lube and have them re-charge and check the compressor and belts. mine was working but not cold as i thought it should be so i had them re-charge it for about 110.00 plus tax and it blows ice cold. 1 thing these other orgers don't say and/or know is that if you put too much in the system you can kill the compressor real easy. take it to jl .
Crooper hedder is having a groanig sound, if he had too much refrigerant in his system the comp would shut off. Most our max's have a combination low press and high pressure cut off switch, his compressor is turning on so I don't think this is his prob. As for jiffy lubes pricing, why pay $100+ when you can follow the dirrections in the STICKIES and do it yourself for under $50 buck guage and hose (re-useable) for next time?
Old Jul 4, 2007 | 02:48 AM
Yeah I'm more into DIY, unless I need special equipment or multiple sets of hands. I have a bit of fluid on my garage floor under the left side of the engine bay. I thought it was excess brake fluid from when I replaced my pads, but maybe it's oil? I'll check into it. I'd ask where it's located and stuff, but I know how to use search and my FSM.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
