Rusting Frame! Noooo!
Old Jun 28, 2007 | 09:22 PM
weedsmoke's Avatar
So after my car gets back from the transmission shop the guy tells me that the frame is rotting out real bad. I knew the front rad support was getting sorta bad but I didn't think the rest was too bad. Apparently the "side frame" or something has to be changed now too. I took some pics with my cell, its not the best quality but you can see the rust for sure!
Here is the driver side lower control arm
the middle bar by the stick linkages
here is the front support under the rad
and the huge hole under the rad
here is more of the centre bar and front engine mount
oh and what is that bolt end supposed to be for??? its got no nut and there is nothing around it
The car has 225km on it so I'm not suprised about the rad support being that bad but what about the centre support under the engine? And the sides right beside the rad support are barely rusted you can check them out here
Also I'm having a bit of a transmission problem now too someone hopefully has an idea about. The bearings, clutch kit and seals and both drive shafts were replaced but now I have a vibration that seems to come from the transmission when coming off the clutch and even when I'm off the clutch all the way in gear (only 1st and 2nd) accelerating hard. Even when downshifting it vibrates. May the clutch need to be worked in? Or is a bearing bad? Damn Ontario and its salted roads!
Old Jun 28, 2007 | 09:37 PM
andrei3333's Avatar
thats pretty bad, but ive seen worse, u can get the lower radiator support replaced, but im not sure about the rest
hey u r from newmarket, im in vaughan, wanna sell me ur OEM SE rims ?
and how did u make a thread with only 4 posts (since april of 06 too, guess u never had a problem with ur max huh)
Old Jun 28, 2007 | 09:39 PM
andrei3333's Avatar
PS: who is that dude chilling over there in the corner by the boxes in the 3rd pic?
Old Jun 28, 2007 | 09:47 PM
99BlackMaxMS's Avatar
Because he donated to maxima.org
Old Jun 28, 2007 | 09:50 PM
MikeSDA's Avatar
mines rusting/rotting up front for the 2 center bolts...Im just going to wait till it gets worse and cut it out and weld a new piece in there, im sure you could find a shop to do that
the other parts look just like some surface rust, no real biggy
Old Jun 28, 2007 | 10:13 PM
maxpeed96plat.'s Avatar
If the rust really bothers u you can get newer lower control arms, rad suuport can b replaced and the engine support can b picked up at a junkyard. I'm not sure if rubber undercoating will help with salt but it could b an option, powder coating? good luck.
Old Jun 29, 2007 | 02:45 AM
alcatranz518's Avatar
Surface rust on the control arms, not a big deal->wire brush paint w/ rustolium pain, = fixed. You can leave it, they won't rust away.
Your core support is typical, Mine is a heavilly driven 1998 w/ 165,000 miles and its similar. $800 approx will fix that at a body shop.
I didn't see any on the other pix that depicted anything to worry about. You are fine. Fix the core support, put the car up on stands, get a good mask and wire brush. Clean all the surfaces and use some rust converter if needed, then paint over w/ some rustolium paint.
Old Jun 29, 2007 | 03:37 AM
matty's Avatar
Weird, but the 2nd, 3rd, and 4th pic all look like different cars
2nd pic doenst even look bad. 3rd, worst, and the 4th really bad.
-matt
Old Jun 29, 2007 | 06:21 AM
andrei3333's Avatar
^^^ thats so true, the 2nd pic seems to be out of place
look at the bolts colour, the driver side in the 3rd pic is yellow where as the same bolt in the 2nd pic is black
Old Jun 29, 2007 | 07:19 AM
matty's Avatar
2nd pic is the rear crossmember mount..I just read the caption
Old Jun 29, 2007 | 09:35 AM
95bluse's Avatar
weedsmoke...sent you PM.
Old Jun 30, 2007 | 03:55 AM
mr2ed's Avatar
5 out of 10 maxima's i've seen at my shop have this problem... i changed out my whole radiator support too...
Old Jun 30, 2007 | 09:02 AM
WhiteA32's Avatar
Wow man that sucks.
Old Jun 30, 2007 | 10:30 AM
hiren_patel_83's Avatar
same thing happened to my radiator support, changed it out, my stock cat was so bad that one day when i was doing my oil change i saw holes in the cat eeeeeeeessssssh!!! changed it out the next day.
Old Jun 30, 2007 | 11:29 PM
maxprivate's Avatar
Black Lion
i didnt even notice that had to swing back up to it.
REDinLV
Aug 15, 2024 12:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
