problems removing old front brake rotors
Hi, I need some advice pulling out the old front rotors. They seem to be pretty old at least 30k old. They are just stuck and don't want to come out. I tried putting some wd40, but I don't they helped too much. What should I do?
There should be a threaded hole inbetween the lugs. Put a 10mm bolt in it and tighten it, it will push the rotor off.
IF you don't plan on reusing the rotors, but out the hammer
If the bolt threading idea doesn't work...
An air hammer would be the easiest (and loudest) solution. That said, I've banged them off with a sledge hammer before. You can try hitting it from the back but I don't think you'll get enough of a swing. I hit them from the front and it just breaks them loose. Try a carpenter's hammer on the area around the lug studs (put lug nuts on the studs so you don't ruin a stud by banging it with a hammer) and use a torch on it if you have one to get it good and hot, if the carpenter's hammer and heat don't bust it loose then slam it with the sledge.
03VQMAX
09-25-2015 04:19 PM
MAXSE5SPD
08-23-2015 12:06 PM
RealityCheck
08-05-2015 06:18 AM
