p0400 : Do I must remove EGR tube from bottom?
Old Jul 2, 2007 | 10:05 PM
nitink's Avatar
Project for 4th July is to librate maxi from evil axis of P0400 & P0325 codes.
P0400 is for EGR & need EGR tube cleaned. problem is don't have jack stands and I am not sure how to get to lower part of EGR tube, Acually I can't even see where lower part goes?
Can I remove EGR tube from top or I must lift the car and work under it?
Old Jul 2, 2007 | 10:11 PM
midnight0045's Avatar
i'd lift the manifold and the TB so you have plenty of room to work with so you can get in there (without the struggle and cuts) and even remove the hole egr assembly in its entirety, clean everything including the vacuum tubes..
Old Jul 2, 2007 | 10:15 PM
maxima985spd
PM your e-mail address. i have very good instructions. read the whole email once i send it to you there are pictures too.
Old Jul 3, 2007 | 01:16 PM
PLUMMAXSE's Avatar
If you pull the TB and the IAC valve that controls the idle you should be able to get to egr tube more easily. I would replace the gaskets for the TB and IAC. That's all I had to pull to replace my EGR valve and tube. This takes a while if you don't have the correct tools.
Old Jul 3, 2007 | 02:13 PM
nitink's Avatar
Wow that would be splendid. Is there any writeup I can lookup? Do I need any special tools for this. I have only basic tools
Old Jul 4, 2007 | 11:30 AM
nitink's Avatar
I have IACV & TB Removed. Upper EGR tube bolts are out but damn I can't reach lower tubr bolts!!!
Any idea what else to do
Old Jul 4, 2007 | 12:09 PM
PLUMMAXSE's Avatar
Not sure what year your Max is, but mine is a 99. Just looked at mine again and the lower nuts that connect the small egr tube should be accessible. One nut on the right is behind the large egr tube which you can get to with a box wrench(14-12mm) and the other one you can use a socket. I did mine and had no trouble getting them out. Looks like the lower egr bolts on the side of the egr valve. The 98-95 max's could have a little more vacuum lines and stuff in the way. What year is your MAX?
Old Jul 4, 2007 | 12:34 PM
JwaxMax99's Avatar
It's tight down there but be a little creative with your socket and wrench and you can get them out. Also, one stud came out with the nut on 1 side of mine.
Old Jul 4, 2007 | 12:59 PM
nitink's Avatar
Mine is 95 and really I can't see where the tube is going, i tried following tube but couldn't locate any bolt
Old Jul 4, 2007 | 01:16 PM
PLUMMAXSE's Avatar
can you post a picture of the area from your 95??
Maybe someone with a 95 can chime in!!
Old Jul 4, 2007 | 02:00 PM
PLUMMAXSE's Avatar
Just looking at my haynes manual, you might have to remove the egr valve to remove the lower part of the tube. Lots of hoses down there and the manual doesn't show where the lower tube attaches.
Old Jul 5, 2007 | 07:16 AM
nick_auto96's Avatar
You don't have to lift the car to remover egr. There is a write-up with detailed intructions. http://forums.maxima.org/showthread....58751&t=496494
However you do not need to cut the bolts as the write up says just get a 12 mm deep socket and big adjustable wrench to open the large egr pipe. After you open the large egr pipe just press it down a little bit for more access. After that, it should be a pice of cake to remove remaining bolts with 12 mm deep socket. After you remove the tube and clean that carbon rocks out of it, don't forget to clean intake hole where the upper egr tube connects to the intake. Mine had a rock solid build up but I cleaned it somehow hehe. Good luck
Old May 1, 2008 | 05:53 PM
golds2045's Avatar
hey, would really appreciate instructions on egr removal
Old May 1, 2008 | 09:33 PM
Morpheus2010's Avatar
I've replaced my egr valve already with a brand new one already. I still get the code and my gas mileage is down.
Old May 2, 2008 | 09:05 AM
UncleMax98's Avatar
P0400 could be caused by bad EGRC-Solenoid, too. You can unplug the green connector and test the solenoid. The EGRC-solenoid has three vacuum connectors. Two on one end, and a single one on the other end. The two on one end are blocked from each other when there is no power. If you apply 12V to the solenoid, the air flows between those two. BTW, the solenoid is adjacent to the transmission dipstick. When mine failed, the resistance of the bad coil was about 300 ohms. The replacement one has 34 ohms. Also, when 12V is applied, the good one produces a loud click. Bad one: nothing.
If you have code P0400, better check those easy things first (EGRC-solenoid, EGR valve, BPT valve, vacuum lines, etc.) before spending hours pulling the EGR pipes for cleaning. My car has 168K miles and the EGR pipes were clean, just a thin coat of carbon inside.
Old Jun 1, 2008 | 10:58 PM
MJStinkfist's Avatar
I'm a noob... is there any way you could post pictures so I can make sure what you are talking about is what I am seeing. I found one green connector that didn't seem close to the trans dipstick. It was actually closer to the KS. Is this the one? You say a working one should be ~34 Ohms?
Old Jun 2, 2008 | 11:49 AM
hermtm2's Avatar
I replaced the EGR valve and cleaned the tube up but the CEL comes out again.
Old Jun 2, 2008 | 12:29 PM
UncleMax98's Avatar
Sorry, I don't have picture. If you see something nearby with a green connector and matches the description (3 vacuum ports), it is probably the EGR-C solenoid.
A coil resistant of 34 ohms does not guarantee a working one, however. It could be clogged, or vacuum lines could be clogged, too. I took apart the old solenoid and it has all kind of crud inside.
If you activate the EGR valve, either by applying vacuum or pushing up on the G-spot, and the engine stalls, then the pipes are clean.
Old Jun 2, 2008 | 01:26 PM
dvpatel99se's Avatar
I have been looking for this darn G-spot without luck. Any pointers for me? What I think is the EGR valve has a hole at the bottom but nothing moves if I stick my finger in there. Its all rusted metal there. I only have 85K miles on the car. I am quickly coming to a conclusion that I will have to take the car to a mechanic.
Help.
Old Jun 2, 2008 | 07:45 PM
maxprivate's Avatar
Black Lion
Is there a write up with any pics for this egr removal and cleaning of all the tube/ hoses? Mine has got to be clogged up. Bad gas mileage, also have traces of leaks all over the manifold so Im assuming all the manifold gaskets need to be replaced. Got quoted $450 to do this from a mechanic, sound reasonable anyone?
Old Jun 3, 2008 | 09:32 AM
hermtm2's Avatar
I had a horrible gas mileage such as 12 to 15 miles/gal in the last winter. There wasn't any CEL. I had been to three shops with a nissan dealership. The shops told me three different diagnosises which were a MAF sensor, exhuast manifold(back side), and entire exhaust system leak. I replaced the MAF and exhuast manifold but nothing happened which were still 12 to 15 miles/gal. The funny thing is that the gas mileage is getting better 15 to 20 miles after on April. I didn't do anything except the outside temperature is getting hot. What I want to say do not go to the shop for replacing the exhaust.
I have the same error code now. I replaced the EGR valve by oem, all of the rubber hoses and cleaned the tube up even though the tube was not clogged. I will replace the EGR-C solenoid as soon as possible.
Thanks.
Old Jul 3, 2008 | 03:06 AM
Well i paid goodyear 153 to do this job for me. We almost had sucess. cel was off for almost the whole day then it came back on. I'm taking it back this friday. I will let you all know what exactly needs to be done. here is the check list so fart
New egr valve(autozone with 2 year warranty)
EGRC soleniod check(done by good year mechanic)
Old Jul 3, 2008 | 03:40 AM
xxchuncexx's Avatar
I just bought a '99 SE Limited and it has the p0400 as well. Who has a good write up? I want this taken care of asap.
Old Jul 3, 2008 | 03:43 AM
xxchuncexx's Avatar
Thanks.
I have a huge exhaust leak. The pipe after the cat rotted off it's flange going to the muffler. Will this cause some of my issues? I thre the p0400, p0303 and an O2 code as well. O2 did not come back. P0303 was new as of yesterday and it's had the p0400 since I got it 2 weeks ago.
Old Jul 4, 2008 | 12:39 PM
Ok well my mechanic finally found out the problem. The car was loosing vacuum in the Air duct. here is the part number we took off it 31u17. I'm not sure if that's correct. He even plugged up the tube that goes to the air duct to prove that it was the problem. SO have your mechanic do a vaccum leak test on everything to make sure they are all working. I've already replace my egr valve and the soleniod works.
Old Jul 4, 2008 | 05:02 PM
G4nismo's Avatar
when you get to the bottom part of the EGR, your going to have to cut off a piece of the stud for the bottom right bolt. your not going to be able to remove the nut w/o cutting off that piece b/c theres a pipe blocking the way...
Old Jul 7, 2008 | 04:24 AM
Well the answer for my problems is definitely the resonator box/air box. Since the mechanic plugged up the hose going to it as a temporary fix the check engine light has not come back on since. I already order it $65 from nissan online.
Old Jul 7, 2008 | 09:14 AM
Dcarlton's Avatar
P0400 Problem
My daughter's 1997 Maxima with 139,000 miles has been throwing a P0400 code for a couple of months now. It also had an O2 sensor code, but replacing the sensor solved that problem. When the dealership looked at it, they indicated the BPT-valve needed replacing and that has since been replaced.
Over the long weekend, I decided to clean the EGR tube as described here hoping that would correct the problem. While I was there, I also cleaned the IAC valve and Throttle body assembly. Both were dirty, but not excessively so. Once I got to the EGR tube, I removed the 4 nuts and worked the tube out after loosening the big pipe to get it out of the way.
I didn't find the clogged pipe as I was expecting and didn't have a clog at the top or bottom parts of the engine where it mounts. I soaked and cleaned the pipe good and went ahead and cleaned both ports where it connects to the engine. Since the throttle body and IAC were removed, it was easy to see all the way through and felt around and didn't see or feel anything that wasn't supposed to be there.
When I began putting it back together, I noticed that the plenum was loose even through the bolts were tightened down as much as they could be (I didn't remove this, but somewhere along the line, someone had). I found a few washers and was able to tighten it down more so that it wouldn't move.
I did get all of the gaskets back in place, no, I didn't replace them with new ones, but they all looked good with no nicks or any tear.
The CEL light has stayed off for 3 days, however, it is back on today. In the process I also checked the EGR valve and it seems to function like it's supposed to; if I press up on it with the engine running, the engine will almost stall.
So what's next? I hate CEL lights and really want this one to go away. Any suggestions are greatly appreciated!
Anyone?
Old Sep 17, 2008 | 10:03 AM
dj.don's Avatar
dj.don@comcast.net
i need the same thing for my maxima
Old Sep 19, 2008 | 02:20 PM
dj.don's Avatar
I need to clean my EGR valve,can i have instructions.
thank you
dj.don@comcast.net
Old Sep 22, 2008 | 04:22 PM
vnramaswamy's Avatar
So what did you do to fix it? Please let me know.
Old Dec 19, 2008 | 02:12 PM
hungtdao's Avatar
I have Max 1999. Unlike model years 95-99, it does not have EGR Solenoid Control as I checked at CourtesyNissan.com website (they provided images of parts). Could some one send me hungtdao@yahoo.com or post an instruction of how to clean the EGR tube. I removed EGR Valve but could not remove the tube that has the top connected to the manifold? Pictures would be nice. Thanks.
Old May 10, 2010 | 01:19 PM
nic8532's Avatar
Anyone have detailed instruction on removing the egr valve for a 1996 Maxima? You can email them to nicjamesallen@gmail.com. Thanks!
Old May 10, 2010 | 07:42 PM
S1cTech's Avatar
Pop the UIM off if you are having issues. I had too. My EGR bolts were on there good and stripping.
Old Jun 16, 2010 | 05:32 AM
jt1199's Avatar
My 1999 Maxima has code P0400. Anyone has detail instructions on how to clean/change the EGR valve &/or tube plz provide w/ pics or simply email me @ jt1199@yahoo.com. Thnx-a-lot...
Old Jun 16, 2010 | 06:17 AM
LeFrank99's Avatar
you should check the how-to section...
http://forums.maxima.org/4th-generat...g-dummies.html
just did it myself, followed the tutorial and everything went well and the code is gone
Old Jun 16, 2010 | 07:54 AM
hungtdao's Avatar
For an instruction of cleaning EGR tube, you can search for my (hungtdao) and other posts on this site:
http://x.nissanhelp.com/forums/maxim...tor-light.html
In addition, I finally got my EGR tube out but I take a lot of efforts by twisting the EGR guide tube and bending (pushing) down the EGR Tube. Once you got a right angle, then the EGR guide tube can be removed.
Old Jun 16, 2010 | 01:19 PM
jt1199's Avatar
Thanks guys for the information...
Old Apr 4, 2011 | 05:21 PM
BkBedstuy709's Avatar
Hey Fella's i have the same code coming up this is like the 3rd time my EGR valve has gone bad with-in the 6 months i had it (bought it in Aug) the 1st two times the car was fine even survived the harsh winter we got in Jan this year. My Mech tells me that he wants to look into it further but to me that small talk for "imma take ur money fool" i told him about the tubes and he told me he doubt it smh i dont want to dish out any more money on that darn thing since i want to modify it with a cold air intake etc. What can be the problem? i want to go to him and show him i kno what im talking about. Thanks Guys.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
jaydot901
Sep 29, 2015 01:18 PM
Sep 27, 2015 08:37 AM
