Misfire problem
Misfire problem
okay so i bought a 96 se for a good price becuase of this misfiring problem. cylinders 2 and 3 will not spark. ive tryed different coils still nothing. fuel injectors are working. had a circuit test done and it seems ecm isnt sending signal to spark to 2 and 3. tryed a different ecm and still nothing. the only code i get is p1320.
nope that didnt fix it. any other ideas? what would they share in common. i mean i even hardwired a new wire straight from the ecm to each coil and still get nothing there has to be a short on something they both share because all other cylinders are firing normally.
Wasn't there a problem where if you had the timing off by one tooth, cyl's 2 and 3 wouldn't fire? Seem to remember something like that from All Motor.
EDIT: http://forums.maxima.org/showthread....h+cylinder+2+3
Originally Posted by yay0
oh **** man i think you got something. i need to check this out tomrw morning. how hard is it to remove the chain cover w/ the engine still in the car?
Most of the time is spent in minor things, like finding all the bolts, getting the PS pump back on (a long pipe and a hammer from the top helped for me...pure ASE certified method), and re-sealing the timing cover/oil pan. It's not all that hard to keep the timing cover from smudging on reinstall, but it definitely requires some picky hand placement and moving around.
FWIW I didn't jack up my motor at all while doing this, did it all with just the RF jacked up with the wheel off (and the hood off, to make things easier on me).
You'll need a variety of random sockets - 10/12/14/17, a 10mm ratchet wrench comes in great handy for some of the stuff, a few extensions. If you have access to air tools, an air ratchet is awesome for all this ****. You'll also need RTV and a gasket cleaner (or paint scraper, new straight razor blade, whatever) to clean/reseal the lower oil pan and timing cover.
Honestly, while I'm in there I'd replace the tensioner and guide with the updated parts per the TSB, and also the water pump, since it's a thousand times easier with the timing cover off.
/longasspost
Unclejunebug
Apr 2, 2016 05:42 AM
