Shift Light Help!
Old Jul 7, 2007 | 03:05 PM
EpzMaxima96's Avatar
Shift Light Help!
I ordered me a shift light from ebay. Im wondering how to install it..I heard its just the power goes to the cigarette lighter in the fuse box, the ground goes to any grounding screw around the area, and the 3rd wire goes to the 1st pin on the ECu which is a red wire with a yellow stripe and your all set? is this correct?
Old Jul 7, 2007 | 03:17 PM
x91max
you need to power it from something that gives 12v when the car is on. i always run it from the fuse box. ground it to a screw on the bottom door panel. that way its coverd.
Old Jul 8, 2007 | 09:20 AM
ok and then u run that wire off the ECU the red wire with the yellow line
Old Jul 8, 2007 | 08:13 PM
Chunger's Avatar
My other car is a Hybrid
Alternate way:
Old Jul 8, 2007 | 08:56 PM
Xzecution'R's Avatar
which shift light did you order? i've been wanting to do this for a while now. thanx.
Old Jul 8, 2007 | 09:41 PM
Chunger's Avatar
Autometer...
Old Jul 9, 2007 | 06:48 PM
umm ebay one..this one to be exact http://cgi.ebay.com/ebaymotors/ws/eB...0170098&rd=1,1
Also did u just screw those 3 wires right there and its works? or was there something there before then u removed it for those 3 wires
Old Jul 10, 2007 | 07:34 AM
Chunger's Avatar
existing screws on the back of the instrument cluster... power, ground and tach signal...
Old Jul 10, 2007 | 07:39 AM
dude thats awesome didnt think it would be that easy lol...
Old Jul 10, 2007 | 08:18 AM
maxima985spd
how much is that shift light? can you set it to light up at certain rpms?
Old Jul 10, 2007 | 09:25 AM
Chunger's Avatar
If you are refering to my Autometer one... yes because there is a separate rpm activated switch (that is actually wired) which uses "rpm pill" modules...
shift light
RPM switch
Check www.jegs.com for prices... I can't remember since it's been like 7 years...
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
