y pipe differences
Old Jul 9, 2007 | 05:44 PM
bipolar's Avatar
y pipe differences
I just found out that my 99 SE-L is a cali.
Fundamentally, what would it take to put a fed spec y pipe on it?
What are the differences between cali and fed spec pipes??
HELP!
Old Jul 10, 2007 | 09:38 AM
bipolar's Avatar
maybe a link???
Maybe someone has a link??
Hard to believe that no one knows this one!!
Old Jul 10, 2007 | 09:47 AM
NmexMAX's Avatar
dot dot dot ...
There are links, and people do know.
There are more, but, at the moment, this is what I found:
http://forums.maxima.org/showthread....pec+conversion
Old Jul 10, 2007 | 09:54 AM
bipolar's Avatar
thanks!!
THanks a ton!!!
Old Jul 10, 2007 | 02:26 PM
d3v0's Avatar
i have the same car and i also read into it. it might be on the forums on that link but i dont know, but if u do look into it u might want to try warpspeed y-pipe. on there site it tells u the difference between the fed and the cali. on my 99 se-l max its a cali. the cali consists of no O2 sensor between the cat and the resonator pipe. mine only has two O2 sensors and they're both located on the exhaust manifolds. so yea hope i helped u out a little
Old Jul 10, 2007 | 02:38 PM
99BlackMaxMS's Avatar
I have read up on this a little bit I have learned that you need to replace both the exhaust manifold from a fed spec maxima along with the front header with the nasty precat attached to it. An 02 sim to fool the ECU and you should be the same as the fed spec cars.
Old Jul 10, 2007 | 02:48 PM
NmexMAX's Avatar
dot dot dot ...
Get Cattman headers and be done w/it. 'Tis what I would do...
Old Jul 10, 2007 | 04:39 PM
That's what I did, plus O2 simulator.
Old Jul 10, 2007 | 06:26 PM
Kevlo911's Avatar
Kevlo for President
Differences are in the stickies, as for aftermarket parts. Headers have been covered 1457374309480 times, so search. pm me if you have a reason for the thread to be reopened.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
doctorpullit
Dec 12, 2015 09:39 AM
