fuel injection cleaner
Old Jul 19, 2007 | 09:03 PM
blimblam's Avatar
sea foam
my car tends to start shaking when at a long stop/idling and the rpm drops below the 500rpm mark then shuts off due to the low rpm. im guessing it's choking and something is wrong with the fuel system? im planing on getting fuel injection cleaner or the complete fuel system cleaner by valvoline. do you think it will help? and does the gas tank have to be about 1/4 left or almost empty for it to work effectively? thanks.
Old Jul 19, 2007 | 09:24 PM
SVI30's Avatar
I used Chevron Techron. This is added before filling up so full tank.
What is the miles on this car and which year is it?
Old Jul 19, 2007 | 09:26 PM
blimblam's Avatar
119,900 nearing 120k. year is 1996. i mean do i add i pour it in at around 1/4 left or less then pour another tank of gas. and do you think it will fix the problem?
Old Jul 19, 2007 | 09:32 PM
LiGhtSoUt's Avatar
it will help it out once you get to about a 1/4 of the tank pour in the bottle then fill it up
Old Jul 19, 2007 | 09:38 PM
blimblam's Avatar
anyone know of any other cures for my car?
Old Jul 19, 2007 | 10:09 PM
VIP Maxima
use bg44k or sea foam
Old Jul 19, 2007 | 10:21 PM
andrei3333's Avatar
whatever you decide to buy will come with instructions, just follow them, u dont want the formula in ur tank to be too concentrated and eat through something its not supposed to...
Old Jul 19, 2007 | 11:32 PM
SVI30's Avatar
Personally, I think it could be more than just cleaning the injectors. But this is the cheapest place to start.
Old Jul 20, 2007 | 12:03 AM
maxgtr2000's Avatar
KH3 by popular demand
Last fuel filter change? Last spark plug change, IAC valve cleaned?
Old Jul 20, 2007 | 12:25 AM
bigpulve+'s Avatar
BG 44K FTMFW....That stuff is amazing....
Old Jul 20, 2007 | 05:20 AM
blimblam's Avatar
i just changed the spark plug 2 days ago. im not sure about the fuel filter. whats the IAC valve?
Old Jul 20, 2007 | 06:18 AM
Nightkid08's Avatar
not to jack... but will fuel injector cleaner dissolve things in the fuel filter so that they can bypass it?
Old Jul 20, 2007 | 08:12 AM
blimblam's Avatar
i just bought a pint of sea foam. i was told to put half into my gas tank the other half into the vacuum hose. is there anywhere else i should put it?
Old Jul 20, 2007 | 08:24 AM
andrei3333's Avatar
dude dont waste money on any of those chemicals, its unlikely they can solve ur problem.
clean the IACV first as maxgtr2000 suggested because its a known issue with 4th gens
Old Jul 20, 2007 | 08:30 AM
blimblam's Avatar
i will tell my friend to clean the IAC valve tomorrow as well when we do the sea foam. will probably change the fuel filter as well.
Old Jul 20, 2007 | 08:39 AM
andrei3333's Avatar
make sure to buy the metal gasket from the dealer for the iacv, dont reuse the old one, its only a few dollars
Old Jul 21, 2007 | 06:29 AM
blimblam's Avatar
im about to go seafoam my car but i don't know where to pur this stuff into.
Old Jul 21, 2007 | 09:47 AM
vuiskool's Avatar
you should buy a carburetor cleaner and then open up till u get to your throttle body and clean it. Theres massive amounts of oil and dirt build up in there and cause ur car to shake and stall. there is a writeup link in the Maintenance section of the 4th gens.
Old Jul 21, 2007 | 09:54 AM
blimblam's Avatar
i can't seem to find the link to the carburetor write up
Old Jul 21, 2007 | 10:04 AM
vuiskool's Avatar
theres two pages. on the bottom of the first page im giving you, theres a link to the second. Enjoy and tell me how it comes out.
http://www.motorvate.ca/mvp.php/517
Old Jul 21, 2007 | 10:43 AM
blimblam's Avatar
vu, the link you gave me says to clean the carburetor but the sea foam would do that also. so should i use the sea foam to see how it works and then buy the carb cleaner?
EDIT: also, thanks for the link. i think that's the problem with mine.
Old Jul 21, 2007 | 11:02 AM
andrei3333's Avatar
ok that link is not sufficient, use this to take the TB off and the IACV if u deside to as well its a lot easier to clean it when the TB is off the engine and u will do a better job too:
Tool required:
ratchet
10m socket
12mm socket
flathead or 8mm socket
pliers or vise grips
1 can of Throttle Body cleaner
1 can of Carb cleaner (I find Berrymans B12 to work fastest)
new throttle body gasket
new IAC Valve Gasket (dealer only)
1) disconnect battery. unclip airbox, unplug MAF Sensor, use pliers to slide clamps holding hoses to airbox down and slide off hoses, use flathead or 8mm socket to loosen clamp holding air tube to throttle Body, remove 10mm socket on side of airbox holding it down and remove air intake assembly.
2) move throttle to fully open position, lift throttle cables one at a time forward and wiggle out of the TB (towards the left of the TB). Unplug 2 Throttle Position Sensor Plugs.
3) remove the 4 12mm bolts holding the TB to the plenum
4) on the bottom of the TB there will either be 2 or 3 hoses attatched. use pliers to slide clamps down and remove hoses. make sure your radiator cap is still on or engine coolant will start to flow out. If hoses have seized on, use flathead to pry the top and break the seal.
5) Remove throttle body. scrape old gasket from both surfaces. clean entire buttefly plate (both faces) and cylinder. there should be no black when done. use only tb cleaner as carb cleaner will remove teflon coating which can later lead to faster corrosion and/or deposit formation
6) locate IAC Valve (triangular unit bolted to drivers side of the plenum right in front of the firewall with a large hose that was connected to the air intake assembly) unplug all 4 plugs.
7) remove 10mm bolt holding EGR Temp Sensor plug to the IAC Valve. (hard to see so you may have to feel around the firewall side for it) It is the only plug of the 4 not directly attatched to the IAC Valve body
8) remove 3 12mm bolts holding IAC Valve to the plenum and remove IAC Valve. Remove old gasket (no need for scraping as it is a metal gasket).
9) spray/wipe the entire inside of the triangular face clean. Spray the inside of the brass housing clean of all deposits. spray base of Idle screw clean to ensure no carbon deposits remain. Be liberal with the spray.
10) replace gaskets and reassemble in reverse order. make sure when attatching the air tube to the TB you tighten the clamp. a loose clamp = a small vacuum leak that probably cant be heard but will be felt (high idle).
before reassmebling, some like to spray remaining tb cleaner/carb cleaner into the plenum to clean it up. This is usually a waste of time since oil coming from the PCV will quickly muck it up again but pooled cleaner may help clean downstream intake when you start it back up. not enough to make a bg difference but hey. If you do this, dont be alarmed by the blue smoke at startup (oil and sludge being burned off). Start the car, take it for a short run to blow any remaining cleaner out and you are done.
Old Jul 21, 2007 | 11:04 AM
andrei3333's Avatar
and no, seafoam will not clean the TB like that
Old Jul 21, 2007 | 11:21 AM
vuiskool's Avatar
buy a carb cleaner. then just spray and pray that when u wipe it out, it shines and your accelleration goes VROOM!
Old Sep 1, 2007 | 11:52 AM
ROCKART's Avatar
wants an I35
yea i would say anything from cleaning throttle body to intake manifold to fuel filter
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
msellas
Sep 23, 2015 09:16 PM
