99 auto. trans. problems
my 99 auto trans has been acting up lately. when its first started after sitting for over about 8 hrs it shuts of when you put it in drive or reverse. It has about 15,000 miles on the trans. Once you get the car to move it seems like it is getting stuck in second but it usually clears up after i drive a mile or so. If anyone has any ideas please respond!!!
fuel pressure
check the fuel pressure. maybe something caught in the fuel filter. I'd take it to the dealer since it's still under warranty.
1) Level. It should be up to the full mark. If not, add as required.
2) Color. It should be bright red and translucent. A brown or black color is a sign of fluid degraded by excessive heat, and/or worn friction materials. A minty pink color is a sign of water contamination.
3) Odor. It should have a clean oily smell. A burned odor is a sign of fluid degraded by excessive heat.
4) Feel. Wipe the dipstick with your fingers and then rub your fingers together. It should be smooth and slippery. A "gritty" feeling is a sign of worn friction materials.
Sometimes the service life of a transmission can be extended by changing the fluid. Automatic transmission fluid is loaded with detergents, so new fluid can clean the insides of the transmission. If you decide to do this, find a shop that uses the Magic Sucker Pump which removes -all- of the old fluid. An ordinary drain-and-refill changes only about half of the fluid.
You said "... about 15,000 miles on the trans." Does that mean this is not the original transmission in the car?
Torque converter lockup
Your symptoms indicate the possibility of a TC clutch which is engaged when it should not be. This could be the result of a faulty TC or TC clutch solenoid valve.
How do I check the torque converter solenoid and where is it located and yes this is a different trans. than original the dealer had to replace it because it wouldnt shift into drive or OD.
Find the harnesses which emanate from the transaxle. One of them terminates in a brown plastic connector with eight pins. This is connector F42, and is located (approximately) above the transaxle case and below the black plastic engine air intake ductwork. With the engine off, disconnect F42. You want to measure the transmission side of F42. Hold the connector such that the plastic latch is at the top. You should now see two rows of four terminals. These are numbered (top row, left to right) 1 - 4, and (bottom row, left to right) 5 - 8. Make resistance measurements between a clean ground and the following terminals:
#1, Shift solenoid B, 20 - 40 ohms.
#2, Shift solenoid A, 20 - 40 ohms.
#3, Overrun clutch solenoid valve, 20 - 40 ohms.
#4, Line pressure solenoid valve, 2.5 - 5 ohms.
#5, Torque converter clutch solenoid valve, 10 - 20 ohms.
There is also a "bench test" procedure for testing these solenoids with a 12 volt supply such as a car battery. However, this requires removal of the shift solenoid valve assembly. I don't know if you want to get involved with that.
The ATF temperature sensor resistance is measured across terminals 6 and 7 of F42.
At 68 degrees F, the resistance should be approximately 2.5Kohms.
At 176 degrees F, the resistance should be approximately 0.3Kohms
