Death of my Max :(
hell, i have gone 100+ in my 95 gle and she took it with style, but i usually keep her at 80 or less because i know its old and that $hit can happen. especially if your not maintaining the fluids and/or mechanical end of things. always check fluids and change at regular intervals especially at higher mileage. and, i've got 165,000 and running strong.
100MPH crusing is not loading the engine much. About 4k RPM and maybe 80-100HP of load.
Likely some type of oiling failure as previously mentioned.
Was there any knocking prior to the rod getting ejected?
Air resistance is a square function of speed. All the other parameters at play should be constant for the same car (surface area, drag coeff, fluid density, etc).
I just did some rough mental math based upon a few facts.
For example: The top speed of a stock 4th gen (5 sp) is rougly 140mph (I have proven this to be the case in my vehicle). This requires a little over 6k rpms, where the stock engine is only making lets say 170 hp roughly.
So we know that roughly 170 HP required for 140 MPH, we can do the math to solve for what would be required at 100 MPH.
HP at 100MPH = 170HP * (100/140)^2 = 86.7 HP.
This is approximate of course. But since my original intent was to state that it was odd that the engine would fly apart under "moderate load" conditions unless something like the oiling system crapped out.
Linkage: http://en.wikipedia.org/wiki/Drag_(physics)
Why are you all still stuck on the load and the RPMs? It's the load, plus the RPMs, plus the fact that it was being sustained for extended periods of time, plus the mileage, plus the fact that it was using conventional oils that apparently don't have names worth mentioning.
If all of those factors did not coincide, the failure probably would not have happened.
If the engine is in poor mechanical condition, then all bets are off. However, there is no reason a high milage VQ (IMHO) cannot manage sustained loading of ~4k rpms and ~ 1/2 rated output. Use of conventional oil of proper grade does not change my conclusion on this matter.
At the end of the day, we are all just hypothesising (guessing) the root cause of the failure...
That's absolutely fine for 95% of Maxima owners, especially if it's being changed every 3,000 miles. But if that's the kind of stuff the engine saw all its life, it's not even slightly surprising that it broke at 180k miles when asked to sustain half its rated output at 2/3 its maximum rotational speed.
Yikes! Never seen anything like that in my life.
I would've seriously been scared shi*less thinking the car was going to blow.
Glad you're safe, and hope that you can get something out of her. Maybe even get another Max?
Originally Posted by Stevenjc
burns a quart every thousand miles.
Jae
OMG... How in the heck did that happen? Where u ever rough on it? I mean these engines can take a beaten but wow... I can't imagine that happening with regular maintenance with proper driving...
Cruising @ 100 MPH being the cause of failure is laughable, quite frankly. It didn't help obviously, but there were definitely some underlying issues there beforehand. A healthy VQ would chortle.
All I am suggesting is that the load and RPM were not such that they should not be able to be sustained for extended periods of time reliably.
"Use of conventional oil of proper grade does not change my conclusion on this matter."
Double
And definitly agree with nismology, something wasn't right previously, however my take on it all is that if you had shut down and pulled over RIGHT before it happaned, ya' know using your .org spidey sense, and checked the oil level................. ibuwouldntseeanyonthestick
Originally Posted by Leroy111
RIP ! just bought a 2000 Mazda 626, 4 banger 2.0L... 5 speed... no more max jollies
only 85k miles on it tho (oooo, shiny) for $5 grand
yikes, i had a rental 626 automatic and not near the power of the max. but, as long as your happy thats all that matters.... put some pics up of your new whip, i'd like to see it.
Why? An occasional visit to the rev limiter isn't THAT bad....
FTMFW!!!!sorry bout your engine nade lettin loose ... but, that means it's time for a 3.5 swap right? ... and a 6 spd to boot!
Cheers!
Originally Posted by 96blkonblkse
man thats crazy. still runs after a rod thru the block..i dont think many other people can say that about there cars.
actually most every car can run with a rod shot through the block. i can show you 2 in the shop right now that run with a rod through it. an altima and a camry.
man thats crazy. still runs after a rod thru the block..i dont think many other people can say that about there cars. thats funny, i just hit about 135-140mph headin home from work on this abandoned stretch of road lol. that would suck if anythin like that happened, like 10kms away from any sort of home or anythin lol..
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
