i thought i fixed the damn thing
Old Jul 27, 2007 | 09:51 AM
burgundyblues66's Avatar
so about a week ago i tried to start my car. it started and would die right away. i figured it was the fuel pump so i replaced it. the car started working fine, but now, one day later, it doesnt start at all. it just turns over but does not start. i have no idea whats going on, any ideas?
thanks
Old Jul 27, 2007 | 10:01 AM
BlackCat's Avatar
RIP '98 Maxima SE
Did you put in a new fuel filter too? Check the fuel pump fuse?
Old Jul 27, 2007 | 10:16 AM
slinky87's Avatar
have you checked your fuel injector grounds and wiring to the fuel pump?
Old Jul 27, 2007 | 10:36 AM
mooze's Avatar
i would agree with injectors. those things are weird. i had a set that would start perfect sometime and others took multi cranks. just replaced the damn things and it was fine
Old Jul 27, 2007 | 12:42 PM
97maxdaddy's Avatar
check the fuse first...
Old Jul 27, 2007 | 01:43 PM
pmohr's Avatar
No more Maximas...
You haven't tried checking your codes, have you? That's one of the first things on a no-start condition.
Old Jul 27, 2007 | 01:53 PM
Klynn's Avatar
Ah is that what that is? My Maxima starts perfect most of the time but every now and again I need to try 2 or 3 times or tap the gas while starting it. Not a big issue so I've never looked into it.
Old Jul 27, 2007 | 03:19 PM
d1max2nv's Avatar
it doesnt have to be ur fuel pump yah know? I mean it could be lost of things, Mas air flow sensor, ur crack position sensor, or ur starter going back. About 6 months back my car had this hard starting problem, i mean i would have to crack it over and over and over again before it started, but the strange thing is that is sounded like the starter was good, until it took a dump about 3 weeks of that hard crackin problem. I would thing its the crack position sensor though...
Old Jul 27, 2007 | 09:20 PM
chillin014's Avatar
http://forums.maxima.org/showthread.php?t=529157
Old Jul 28, 2007 | 01:53 PM
i mean, its not the fuse because i checked that. there are no codes. how would i check the injector grounds?
Old Jul 28, 2007 | 03:03 PM
ok, brand new developement in this story.
i go to work on the car, and lo and behold, it starts just fine.
i guess it isnt the fuel pump, what could this be????
Old Jul 28, 2007 | 03:53 PM
chillin014's Avatar
so i guess that means you completely ignored the link i gave you.
Old Jul 28, 2007 | 05:43 PM
wiggafly808's Avatar
Did you do anything at all?
Or did it just start up with no work on your part?
If it's the latter, perhaps it is the ground from your battery. Be sure both your battery terminals are nice and snug, and your ground wire is snug on the body.
Make sure there isnt any corrosion or anything on them.
Good luck!
Old Jul 29, 2007 | 10:47 AM
no, this is different. it doesnt turn off while driving. it just didnt start, no matter how much i cranked it.
then it randomly started just fine
Old Jul 29, 2007 | 11:40 AM
chillin014's Avatar
oh are you serious?
Old Jul 29, 2007 | 12:07 PM
yeah, i dont know what the hell is going on. i dont even know what could cause something like that. there are no codes
Old Jul 29, 2007 | 12:09 PM
chillin014's Avatar
how about reading the thread i gave you a link to?
Old Jul 29, 2007 | 01:44 PM
yeah, i have read it twice already, thanks for that. what is an ects though?
Old Jul 29, 2007 | 01:47 PM
chillin014's Avatar
http://forums.maxima.org/showpost.ph...4&postcount=34
engine coolant temperature sensor
Old Jul 29, 2007 | 02:08 PM
d1max2nv's Avatar
sounds like ur started bro. Mines had did that it would just crank and crank, and some days it would start up just fine. Then it went dead on me one day at work.
Old Jul 29, 2007 | 05:08 PM
chillin014's Avatar
who are you talking to? me?
read the thread, there's nothing confusing about it, really. I replaced the ECTS after having the same problems you did and the car has not stalled since. Not all problems have IDENTICAL symptoms from car to car, you know. If you are 100 percent sure its not the ECTS, then there are plenty of other suggestions in the thread. I was just trying to show that someone already posted a thread like this before and the ORG came together with its advice already at some point...so i was trying to prevent redundancy.
Old Jul 29, 2007 | 08:28 PM
ok, another development, my check engine light just came on. code 180, or fuel temperature sensor. wtf?
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
DrVee
Sep 4, 2015 12:18 PM
mikebla
Sep 3, 2015 05:37 PM
