Greddy Emanage Blue pinout
Old Jul 31, 2007 | 01:12 AM
jordandalley's Avatar
Hey everyone - I am after a pinout for a Greddy Emanage Blue. I have searched this site high and low and found pinouts for the Greddy Emanage and Emanage Ultimate, but it seems the Blue has different wire colours.
Is there or was there ever a pinout for the Emanage Blue??
Cheers guys
Old Jul 31, 2007 | 04:23 AM
Kevlo911's Avatar
Kevlo for President
http://www.mohdparts.com/
When the site gets back up later today you will see the how to and eblue pinout/manual...
Old Jul 31, 2007 | 01:45 PM
thanks Kevlo911
Old Aug 2, 2007 | 01:42 AM
So now i've hooked up the greddy emanage wiring I'm faced with setting up the "Air-Flow Type" selector. Does anyone know what this setting should be for an A32 MAF???
Old Aug 2, 2007 | 06:04 AM
Kevlo911's Avatar
Kevlo for President
What are the options?
Old Aug 2, 2007 | 05:30 PM
Never mind. The rotary switch settings are 7-0-1 for the Maxima.
I'm wondering if anyone has a repository of *.gsc files with default maps for certain mods.
For those of you wanting a emanage blue pinout.. here's what I did..
The only wires used in Greddy Emanage Blue for the Maxima are Red, Black, White, Green, Grey and Brown - All the others you can ignore as I think theyre all used for secondary MAF if you have one (twin turbo setups) and VTEC's.
1) Tap/Splice the Negative Power Wire
- Emanage Colour: Black
- ECU Wire Colour: Black
- ECU Pin #: 25, 55, 10, 19, 32, 108, 116, or 124 - Or just ground it somewhere to the chassis.
2) Tap/Splice the Positive Power Wire
- Emanage Colour: Red
- ECU Wire Colour: Red
- ECU Pin #: 67 or 72
3) Tap/Splice the RPM input source
- Emanage Colour: Brown
- ECU Wire Colour: White/Green
- ECU Pin #: 5
4) Tap/Splice the TPS (Throttle Position Sensor) wire
- Emanage Colour: Grey
- ECU Pin #: 23
5) Cut the MAF Sensor Wire
- ECU Wire Colour: White (Best to go with Pin Number as there are multiple white wires)
- ECU Pin #: 54
6) Connect the MAF Sensor Wire coming from the ECU to the Green Emanage Wire:
7) Connect the White Emanage Wire to the wire going to the MAF
Here is an ECU pinout I scored off HLH0501/Mohdparts.com
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
