2002 auto tranny in a 4gen
Originally Posted by Kevlo911
Different electronics, won't work with our "computer system"
Originally Posted by heynow
Just a Question: A tranny from a 2000-2001 would be a closer match, right?
Originally Posted by pmohr
So it's the same RE4F, just different electronics? What if you swap out the solenoids / VB w/ solenoids?
Pretty sure alot of the tranny is different, I am told the internals looks totally different.
Originally Posted by t6378tp
will a 2002 auto tranny bolt directly into a 4gen with a 3.0
my friend has a 2002 tranny for sell but I can not find any info about this swap
Connectors
Where the VSS from your A32 will be mounted
Inhibitor Assembly
Anyway, I think you'd be OK just changing out the external controls from the A32 to the A33 AT. The case looks the same, but be sure your A32 parts function correctly.
Originally Posted by made in china
I'll be putting a 2004 AT in my 97. However, I'll be using the 2004 ECU and TCM also. Here's some pics of the 2004 AT which should be the same as 2002:
I35 was available in 2004 MY, it was the end of the A33 line. Maybe A34 Max began in 2004 as the I35 was sidelined?
Connectors
Inhibitor Assembly
Connectors
Inhibitor Assembly
Only if it's one of the uncommon 4AT automatic in '04, most were 5AT. I believe only early '04 SLs had 4AT? Not quite sure. If it's a 5AT then even with the TCM I don't think it would work, between trans mounts and the shift linkages.
from the posts looks like it will not work, it's a 5atquestion if I still wanted to make this work I would have to a 3.5motor, 5at tranny and both the engine and tranny controller along with the harness
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
