Top Speed
What's the top speed anyone has reached in there 99 Max. I can't seem to get my 99 SE auto over 120 - 125 MPH. I have every mod available except a supercharger. I thought these could go 140 stock. Does anyone know if the '99 had a governor or a fuel shut off? Thanks for the help! - Kevin
I got an automatic 97 SE (fully mechanically stock; only 80% cosmetic customized) and did 130 mph @ 5500 rpm with two adults in front, two kids in the back, and a trunk full of loaded suitcases and bags.
ps i take my 96 gle to 140 whenever i have the chance. that was like twice.
Speed Limiter on autos
Re: Speed Limiter on autos
Originally posted by bobl
From what I understand autos all have a speed limiter programmed into the ECU.
i thought gxe's w/o comfort and conveince package have limiters. all gle's, gxe WITH C&C,and se's don't have any limiters just a rev limiters
I have a 98, but this may relate to you. When I just boguth my car used, I guess the previous owner didn't quite have the passion for the Maxima as I did. I took it for a top speed run and couldn't get it past 120-125. This on a 5 speed SE!! I did some minore maintenance to see whats up.
Found the culprit: fuel filter. Once I changed that, my baby charged right up to 140!! Boooya!!
I guess with these 4 valve engines of today, their feul thirst above 3000 rpms must be intense, so any starvation from the feul system, like a clogged feul filter, would adversely affect the top end.
Hope this helps.
DW
Hope this helps.
DW
Re: 140 MPH at any time i want
No, smaller wheels. Not emmissions, not weight. Smaller wheels. That's it.
DW
DW
Originally posted by darek
I have a '95 max and it goes to 140 whenever i want it to!!!!!!!!!!!!!!!! The thing is that '95-'96 are faster than the '97-'99 because they are much lighter.
Re: Re: 140 MPH at any time i want
DW
DW
With 15 inch alloys a max is faster and lighter.
RE: Speed Limiter...
From what I understand the speed limiter is set at 131 MpH. However, I do not believe this can be performed normally. I believe this can only be performed without a driver (after all, tesing is done without a driver). The top speed capable (without limiter) is actually over 140 MpH. I believe the track tested speed without limiting has a high of 142 MpH. Just to show you the Maxima has more than expected
I hit about 150, but without seeing any problems from the ECU, I have an S/C, Y-pipe, Catback, Valvebody Mod. I think if you had enough room you could get going faster, my car accelerates slowly from 125-135 but after that it pulls harder to around 150, I don't know for sure because the Speedometer runs out at 140. The pin started to cover up the corner of the Digital Odometer. So I am guessing that it was around 150.
Re: RE: Speed Limiter...
Originally posted by medicsonic
I'm starting to think that the Speed Limiter is a random thing, some have it, some don't.
That's what I've been screaming. The only way to know for sure if you have a limiter or not on your GXE is to try it and see what happens.
Well, I've been screaming that and "O/D off does nothing but lock out 4th gear!!!"
Top speed
This is what I've always thought;
the speed limiter is determined by one thing and one thing only, what type of tires came on your car from the factory. If you got H rated tires, no limiter. If you got s rated tires (or antything below H) , then you had a limiter.
The C&C package ties into the limiter thing because that package probably upgraded the tires as well. As for the random thing, maybe the C&C package for 95 did not have the tire package, but the C&C package for 97 did. I think the package offering keeps changing every year because new features and add ons become available as the car line gets older. For example, side airbags became available on 98 Maximas, and standard on 99s, etc.
So, while the C&C package may be a good guide as to whether your maxima has a lmiter or not, if you have the original invoice (I know, highly un-likely), the tires will tell you the real story.
DW
DW
DW
DW
I hit 140 on the speedometer a few weeks ago coming over the Dumbarton bridge. I reached it just as I hit the crest of the bridge. I started to go downhill will plenty left (accelerating) in 5th before I shut it down (I was afraid of cops hanging down at the bottom). I don't think I was actually going 140mph, prolly a few mph less for speedometer correction and the ~1% difference in tire size...
96's
I always heard the 96's were the fastest year...im a lot guy at Nissan and I can attest to the fact that for some reason or another whenever i drive a 96 it always feels like it accelerates quicker than a 97 or newer....dont know why...and the 2000's while not actually being quicker feel faster just because of the torque advantage...ahhh ant torque grand.
a little over 120 and it still kept going but we stopped. there was 2 ppl in the car going slightly up hill with a Grand Prix tailing us about 4 car length behind as we slowly pull away from it.
Originally posted by 92ZexMaximaSE
Gosh, then maybe I should feel blessed.. I seem to hit 140 with no problem.. Just wish I had more straight empty highway to do it..
The Phantom speed/rev limiter strikes again..
haha
I hit the N on my speddo...the one that says unleaded fuel o(N)ly...but i have a 5 speed and i scared the **** out of the passanger....country road racing...plus i was on a bit of a down hill so falme if you will but i have witnesses...the passanger and the mustang gt i left behind me!....don't know the speed but well over 140
What in the $^&%&^% is a "C&C" package. And I did say I had a '99 SE Auto which by the way only came with the high performance Toyo. I think Proxas or something like that. I have since changed them out. There's got to be a way to check? How come everyone on this sight has an opinion but no one ever seems to really know?
hmmmm top speed.... how do we get rid of the speed limiter cuz i have a '97 GXE 5spd... and it has one i believe... even though i've never run it up past 115 because i believe in some sanity =)
well.... maybe cuz i never had the opportunity
Re: Re: RE: Speed Limiter...
That's probably the 5th gens, there are MANY auto 4th gens that have climbed to 140, not 131.
98 SE 5spd
I know you are asking about a 99, but the fastest I ever took my 98 SE 5spd was 180KM/h. There is really no good roads in Toronto to take it any faster, plus I can't afford to have a speeding ticket since I am applying for the force.
Re: Re: Re: RE: Speed Limiter...
Interesting that they put 130/131 limiters on the 5th gen and not the 4th gen, unless its 117 or so for GXEs. I guess Since the 5th gen has a more capable top end than the 4th gen, Nissan had to put the governor there, otherwise it doesn't make sense, since both the 5th and 4th gen come shod with H rated 130 mph tires, at best.
I notice that other manufacturers are governing their cars to 130 as welll, even though they are capable of way more. Example, the Lexus LS 430, Mercedes Benz E 420.
Originally posted by h2o467
I think you are correct. I can't see to get my 5th gen over 130/131 without the fuel cut kicking in. Have to figur out how to disable that. I was not aware of the fuel cut-off the first time I brought it up to that speed. I thought there was something wrong with the car.
Re: Re: Re: Re: RE: Speed Limiter...
[/B][/QUOTE]
The other reason they are limited to 130 is because of the H Rated Tires.....the stock tires performance rating often determines where the governor is set on a car....H tires arent made to handle more than 130, thus the 130mph speed limiter on the 5th gens....otherwise it would be lawsuit time when someone did 141 and blew a tire.
[/B][/QUOTE]
Re: Re: Re: Re: Re: RE: Speed Limiter...
Good Point. Makes sense to govern the car at the top speed of the manufactures tires. I just installed the Bridgestone Potenza RE730s on my car (225/50ZR16). Amazing tires. What a step up from the Toyo stock tires. Will Nissan remove my speed limiter now?
Re: Re: Re: Re: Re: Re: RE: Speed Limiter...
